89 crx d16z6 swap no spark HELP!!!HELP!!!
Old 10-22-2009, 05:13 PM   #1
Greenhorn
Rep Power: 0 davkupiec is on a distinguished road
Exclamation 89 crx d16z6 swap no spark HELP!!!HELP!!!
hi im new to the site and new to the car also lol just bought it its a 89 crx hf with a d16z6 motor swap i have a p28 ecu with a jumper harness. Also i have a obdo stock wire harness with a obd1 distributer. I have read a ton of stuff about the wiring for this but i just cant get the car to start. I hear the main really work under my feet and also hear the fuel pump kick on. Also i am getting power to the distributer.I have checked all the grounds and they are good to but is there just a ground wire for the distributer? If any one has any idea on why i just might not be getting spark i would greatly appricate it starting to go crazy!! And im not all that great with the whole wiring thing either but do know how to do it if someone just tells me how. Thanks again
davkupiec is offline   Reply With Quote
Old 10-22-2009, 05:43 PM   #2
HS Vendor
SwapShopRacing's Avatar
Location: 650n Barranca ave #a Covina, Ca 91723 (626) 261-4052
Ride:  00 Civic, 08 Fit, 98 EK
Rep Power: 5 SwapShopRacing is on a distinguished road
Send a message via AIM to SwapShopRacing Send a message via Yahoo to SwapShopRacing myspace  FaceBook
Have you tested the distributor? If so I would start by going over the dist. wiring. Are you using the HF harness?
SwapShopRacing is offline   Reply With Quote
Old 10-22-2009, 05:49 PM   #3
Greenhorn
i have tried two diff distributers the one that came with the car and then i got another on from a junk yard that they had told me that it worked but who know but all i really know by testing it is that i am getting power to bothe the neg and pos on the coil aslo i know that its has brand new wires and cap on it is there another way to actually test the distributer
Old 10-22-2009, 07:22 PM   #4
HS Vendor
Yeah you can test the igniter they tend to go out a lot, but I would think that one out of two should be good. Are you getting any cel's? Have you gone over the distrib wiring from the OBD1 conversion?
Old 10-22-2009, 09:10 PM   #5
Greenhorn
cels? sorry like i said im not to smark with the wiring thing and ya i went over the wiring all the colors match up besides the to white wires the one big on and the one small one i put the smaller white wire to the obd1 distributer and the bigger one to the all yellow with green stripe wire but other then that they all matched up to the old wire harness!!! but still nothing
Old 10-22-2009, 09:34 PM   #6
yeah, it's a vtec.
c-rex-beat's Avatar
Ride:  89 crx/z6
Rep Power: 4 c-rex-beat is on a distinguished road
myspace
with the dizzy, did you make a jumper harness or buy one? There is usually 2 white wires that need to be switched around. I would start with that first.
c-rex-beat is offline   Reply With Quote
Old 10-22-2009, 09:40 PM   #7
Greenhorn
i had just bought the car and yes there is a jumper harness on it and i tried switching the two white wires and still nothing at all
Old 10-22-2009, 09:43 PM   #8
Greenhorn
also i person that i had bought it off of he said that it ran for like 10 miles then shut off but i dont know if that was true or not thats just what he said!!!
Old 10-22-2009, 11:48 PM   #9
Ride:  06 Chevy Silverado
Rep Power: 88 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
Please post these questions about 88-91 crx's in the ef forum. You posted this in the ew forum. I moved this for you to the proper forum.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
Old 10-23-2009, 12:55 AM   #10
yeah, it's a vtec.
c-rex-beat's Avatar
Ride:  89 crx/z6
myspace
is your check engine light on?
Old 10-23-2009, 02:21 AM   #11
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
Possible bad ECU but not likely. I would get a Helms or Haynes manual so you can test the different dizzy parts and know what you're looking for. I've had a coil and an igniter go out on the same dizzy. I've also just had a really bad cap and rotor combo and the car wouldn't run.
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is online now   Reply With Quote
Old 10-23-2009, 09:45 AM   #12
Greenhorn
yes the check engine light is on but dosent it usally stay on untill the car can run? and i just really think that im going to but a new dizzy off ebay they are going for 75 dollars and then if that dosent work then i deff know that its something else but if any one has a better idea then let me know thanks for the help guys i will let u know what happins
Old 10-23-2009, 11:31 AM   #13
jlicrx's Avatar
when you turn the ignition 'on', the Check Engine Light should come on for 2 seconds (fuel pump primes) and then the light should go off
ZCspeed Racing
Old 10-23-2009, 02:50 PM   #14
Greenhorn
ok then yes the check engine light stays on then
Old 10-23-2009, 04:45 PM   #15
Rep Power: 1 munchies91crx is on a distinguished road
if the check engine light stays on its your fuel pump.
munchies91crx is offline   Reply With Quote
Old 10-23-2009, 05:22 PM   #16
Greenhorn
but i would that cause me to not get spark when im turing the car over alo i disconected the return fuel hose off the fuel rail and a ton of gas came out
Old 10-23-2009, 05:30 PM   #17
HS Vendor
If it's OBD1 the Jumper Harness you are using should be wired up to jump your CEL (Check Engine Light) and read the code from your dash. Or for OBD-0 the LED on you ECU will blink out the code. Anyway, you count the blinks, fast blink = 1 long blink = 10. You can find the trouble codes on the following page: Honda ECU Trouble Codes
This should help you to figure out what is going on.
Old 10-23-2009, 08:15 PM   #18
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
Identify/Fix the cels, then post back.
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
Old 11-01-2009, 10:43 PM   #19
Greenhorn
Rep Power: 0 iluvhonda is on a distinguished road
check crank sensor also ecu might be bad check voltage from the pins that send signal from ecu to distributor also does the distrubutor have internal or external coil? if coil is external and u did not replace it it might be the issue
iluvhonda is offline   Reply With Quote
cx to d16z6 no spark cxz6sohc HYBRID -> EG-EK / DC 3 01-10-2008 08:56 AM
d16z6 has no spark b16a eg HYBRID -> ED-EF / DA 10 03-29-2007 01:32 PM
How do you remove the spark plug seals on a d16z6 projectxspeed General Tech and Maintenance 14 10-08-2004 10:53 PM
No SPARK!!! (D16Z6) in 90 hb civic Carnage HYBRID -> ED-EF / DA 7 12-19-2003 01:30 AM
NO SPARK (d16Z6) in 90 hb Carnage HYBRID -> ED-EF / DA 3 12-18-2003 09:42 AM
