89' HF Bogging..........
Old 01-21-2007, 10:41 PM   #1
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 27 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Default 89' HF Bogging..........
Help........please!!!
My 89' CRX HF bogs down around 2500-3000rpm. I cant figure out what it is, can anyone help me with the possible causes of this.
Thanks
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 01-22-2007, 02:26 AM   #2
Got Rice?
801CRX's Avatar
It idles a little funny, it would drop then go back up then drop again and so on. But it doesnt always idle like that, some days its fine and others it idle funny.
Old 01-22-2007, 11:11 AM   #3
I need some ligaments!!!
turbo sol's Avatar
Location: laurel, montucky (ten minutes out of billings)
Ride:  89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
Rep Power: 17 turbo sol has a spectacular aura aboutturbo sol has a spectacular aura about
Send a message via MSN to turbo sol myspace
my hf bogged really bad under acceleration and a new cap and rotor fixed it...the rotor was totally burned through. yeah change the cap and rotor for a start cause i'm gonna go out on a limb and say you've never done a cap/rotor change on your car before and i'm sure it needs one. they're cheap...go to napa and get a bosch cap with brass terminals and a bosch rotor with a brass center.
car + vinyl = big hp!!!
wipe your mouth, there's still a tiny bit of bullshit around your lips
Achmed the dead terrorist:
I once threw a penny between two jews and watched them fight to the death! I did the same thing with two Catholic priests except I threw in a small boy! And the winner had to fight Michael Jackson!
(\__/)
( 0.o )
( > < ) The bunny will rule teh world! Bwahahahaha!!!!
turbo sol is offline   Reply With Quote
Old 01-22-2007, 02:26 PM   #4
Got Rice?
801CRX's Avatar
I changed the cap and rotor a couple days ago, because that was my first thought also. But it still does it, I think ill check the valve lash and replace the 02 because emissions is coming up.
Thanks guys!!!
Old 01-24-2007, 07:08 PM   #5
The Riced Sleeper
ThatGuy4life's Avatar
Ride:  2000 Si w/B18C5-R swap
Rep Power: 45 ThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud of
myspace
I'm still going through the same thing but mine bogs at 5500rpms. I've basically troubleshoot almost everything I could think of, only thing left to do is replace the fuel pump, but what's the valve lash?
Originally Posted by reckedracing View Post
it takes a strong person to open themselves to criticism, and a weak person to sit behind a computer screen and criticize
Dam, did I just beat u in my Honda? Sure did, now your girl wants to get at me (True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." (2nd part of sig. taken from 89CRXZC)
http://racingsouthwest.com/forums/in..._item&CID=1708
ThatGuy4life is offline   Reply With Quote
Old 01-24-2007, 10:37 PM   #6
The Riced Sleeper
myspace
Originally Posted by Blanco View Post
Before you replace the fuel pump, check the main relay and O2 sensor.
Valve lash is setting the distance between the rocker arm and tip of the valve stem. Your repair manual should tell you how to do it or I can post the link after I get home.
the link would be nice as I don't know where the manual is, as for the main relay how would I be able to tell if it's bad, isn't it all blacked out
Old 01-25-2007, 01:30 AM   #7
The Riced Sleeper
myspace
06 (70)
It's for '92-'95 but the procedure's the same.
I just started doing this and it works pretty good. I set the #1 cylinder to TDC via the mark on the crank pulley and set the lash on #1, the intake of #2, and the exhaust of #3. Then I rotate the crank 360* (the cam gear will rotate 180*) using the TDC marker on the crank pulley to line it up and I set all of #4, the intake of #3, and the exhaust of #2. It saves a few minutes and it's a lot more accurate than just sticking something down the spark plug tube.
thanks man
bogging sometimes hazzardboy95 Civic and CRX - EF 3 01-08-2007 04:26 PM
b16 obd0 - Bogging Nightmare! wougoose HYBRID -> ED-EF / DA 19 11-23-2006 05:09 AM
d16y5 bogging bad byebyebaby HYBRID -> ED-EF / DA 5 11-22-2006 10:10 PM
Civic Bogging Out paraplegic Civic and del Sol - EG and EK 1 07-27-2006 04:56 PM
bogging at 4500 rpm sil180drifter Forced Induction 6 09-03-2003 09:04 AM
