89 SI - 94 conversion
Old 06-20-2009, 10:42 AM   #1
Greenhorn
Rep Power: 0 Hot89SI is on a distinguished road
Default 89 SI - 94 conversion
I am brand new to this site as I inherited this car from my son. Probably doesn't make sense, but the price was right and the SI motor through a rod through the block after my son sucked up a load of water into the intake. Here goes; I put a 94 D15B8 motor into the bay of what was once a D16A6 89 SI. I have the ECU from the 94, but currently running the older 89 ECU. I put the older distributor from the 89 on the newer engine since I didn't have the wiring harness. I am utilizing the intake and header exhaust from the 89 though. The car runs rough and occasionally I get a check engine light (the car actually runs better with it on); gas mileage is down and it won't pass emissions. When you get on it though it seems to pull pretty good and doesn't miss. Do I have to swap heads or is there a conversion for wiring to go to the 94 ECU. Any help would be greatly appreciated; I work on Post at Ft. Lewis and can only get the car registered once I get emissions to pass.
Hot89SI is offline   Reply With Quote
d17 conversion b16acrx213 ECU's, Electronics, and Tuning 4 02-07-2007 08:42 PM
itr conversion stumpy32 Wheels / Suspension / Tires / Brakes 1 07-22-2006 02:53 PM
why not to do a RHD conversion reckedracing Body / Exterior / Interior / Cosmetics 33 06-08-2005 12:44 PM
5 lug conversion sihatchback_RL Wheels / Suspension / Tires / Brakes 4 06-06-2005 05:38 PM
Help W/ Obd-1 Conversion darkracer HYBRID -> EG-EK / DC 4 04-18-2003 12:43 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
