can anyone please help me i need to know where the wires go from the drivers side shock tower into the engine wiring harness the car has a d16a6 in it and the drivers side plug is the small 8 wire plug thank you to anyone who can help
¿GANGSTA GREMLIN?
Ride: 91 CRX si
to a resisor box..
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#6 |
the diagram is for the Si/HF 8-wire connector at the driver's side - don't know what you mean by small plug - it is smaller than the DPFI 14 wire plug
ZCspeed Racing |
#7 |
ok i just wanted to make sure as i have 3 wiring harness for the car 1 is an si that i had to remake 1 is a jdm si harness and the other is a dpfi thats why i was asking
what is the eacv and where is it located |
#9 |
the Fast Idle Control Valve is only found on the 89-91 (not on 88) Si D16A6, on the back of the intake manifold
![]() __________________
ZCspeed Racing |
#11 |
the TPS connector is a 3-wire connector with yellow/white, red/blue and green/white wires
ZCspeed Racing |
#12 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
post a pic, of what your talking about...and yes tps is 3wire
#13 |
EACV, yes - to the right of the FICV in the picture - has 2-wire connector with blue/yellow and black/yellow wires
ZCspeed Racing |
| wiring problems h22 | ccastro6330 | Accord | 2 | 08-19-2009 05:23 PM |
| wiring problems | b18c4 | ECU's, Electronics, and Tuning | 0 | 10-21-2008 11:20 AM |
| crx wiring problems | pimpkid | HYBRID -> ED-EF / DA | 1 | 07-29-2008 03:58 PM |
| crx wiring problems | kwninjaaz90 | Civic and CRX - EF | 11 | 06-17-2008 04:42 PM |
| EG Wiring Problems | B18C1 Eg | HYBRID -> EG-EK / DC | 1 | 07-29-2004 09:56 AM |
