91 Civic fuel pump removal?
Old 07-22-2008, 08:03 PM   #1
Rep Power: 6 sleeper1.6 is an unknown quantity at this point
Default 91 Civic fuel pump removal?
I have a 91 Civic that won't start. It will turn over but it just won't start. I can't hear the fuel pump prime at all, even when I pulled the back seat up. But any way I tried to take the fuel pump off to see if it was doing anything, but I don't know how to take the pump off. So any info at this time would be great. Thank You.
sleeper1.6 is offline   Reply With Quote
Old 07-23-2008, 12:47 AM   #2
My name is Byron.
efhondakid's Avatar
Ride:  `89 DX Hatch w/JDM B16
Rep Power: 110 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
How do you know its the fuel pump? It might be your main relay. But to get to the fuel pump you have to drop the tank.
Looking for a P28 and B-series turbo parts, PM me.
efhondakid is online now   Reply With Quote
Old 07-23-2008, 08:11 AM   #3
Well we pulled up the back seat and it's right there. And on the 92-95 civic it's the same way.
Old 07-23-2008, 10:27 AM   #4
My name is Byron.
efhondakid's Avatar
That cover is for the sending unit, the acutal fuel pump is about 8 inches behind that, you have to drop the tank to get to it trust me.
Old 07-23-2008, 12:17 PM   #5
Well damn, the main relay you were talking about how would I go about fixing that? I don't mess with fuel pumps and wiring that much as you can tell. Oh and it can't be a fuse I checked that.
Old 07-23-2008, 02:21 PM   #6
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Get a ratchet and a 10mm socket. Remove the lower dash trim, remove the two bolts holding the hood release to the wall, then reach up, remove the one bolt holding the main relay, unplug it, and reverse for reinstallation.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 07-23-2008, 07:05 PM   #7
I know everything
Ride:  89 CRX HF, 96 Accord EX, 88 Dodge Daytona w/t-tops (Big project)
Rep Power: 0 the.original.kermit will become famous soon enoughthe.original.kermit will become famous soon enough
Or run live 12 V to the pump. If it doesn't run, it's bad. If it does it's something else.
If it's the pump, I would suggest that you take it in. Even for more experienced mechanics, tanks can cause headaches as the lines are almost always rusted to piss. Same with the bolts. Speaking from Michigan that is, if you are south, that's probably going to be different.
the.original.kermit is offline   Reply With Quote
Old 07-23-2008, 07:17 PM   #8
I'm from the south, I don't have rust problems. But the cars has been sitting around for 2 years. I'll try the 12v battery idea. Thanks a lot.
Old 07-23-2008, 07:54 PM   #9
Ok, I took my NRG Nano performance battery to the plug and there was nothing. I didn't "plug" the wires in I just took them and touched two open wires to the male plug. Would that work or would I have to cut the female plug and make a new one?
Old 07-23-2008, 07:57 PM   #10
I know everything
I'm assuming that's a car battery...
Yeah, as long as it's charged up good and you are making good contact, it should have fired up
Old 07-23-2008, 08:10 PM   #11
Yes, it is a car battery, but it is small and I mean small. It looks like a motorcycle battery. Like 9 lbs at 180 AMPs.
Old 07-23-2008, 08:23 PM   #12
I know everything
yeah, it should work, probably time to get that pump replaced
Old 07-23-2008, 08:31 PM   #13
Thanks a lot man. Well time to drop a gas tank!
Old 07-23-2008, 08:33 PM   #14
I know everything
No problem, happy to help!
Old 07-23-2008, 10:24 PM   #15
Well got the old fuel pump out, and boy does it look like crap. It has rust all over it, from top to bottom. I hooked it up to a battery and it did nothing... it's dead. Were going to drain all of the gas tomorrow, and go from there.
Old 07-23-2008, 10:33 PM   #16
I know everything
LOL, wow, obviously you don't live anywhere close to me. On a 15/20 year old car, you might as well kiss any fittings on the fuel/brakes goodbye. It probably would have taken me several hours to drop the tanks on my CRX. The strap bolts are so rusted that I doubt that I would be able to get them withoug breaking or cutting them.
Well goodluck, also, why drain the gas and replace the tank... just replace the pump. I believe this one should work for your application.
eBay Motors: NEW FUEL PUMP OEM 1988-1991 HONDA CIVIC (item 160191120063 end time Aug-11-08 17:26:38 PDT)
Old 07-24-2008, 08:53 PM   #17
Oh I'm not replacing the tank itself, just the pump. We're taking the old gas out. I did that at first but didn't get all of it out because we didn't jack the car up on the front left hand side. But thanks for the fuel pump price on ebay.
Forum Jump
1990 Civic Fuel Filter Removal Thurobred General Tech and Maintenance 2 02-27-2008 04:41 PM
no fuel pressure, fuel pump wont turn on gilronaldo ECU's, Electronics, and Tuning 2 11-21-2006 03:57 PM
Ls swap...Fuel pump or fuel filter Questions. CRXSI91 HYBRID -> ED-EF / DA 5 06-15-2005 05:32 PM
OBD2-1, P28, Hondata S100, Fuel Pressure,Fuel Pump khai_tuan_nguyen Parts: For Sale/Trade/Wanted 6 01-20-2004 03:47 PM
93 Cx A/c Removal & Fuel / Other Lines. Engine Rem Hybrid93Hatch HYBRID -> EG-EK / DC 1 03-05-2003 11:07 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
