Ride: 91 integra with ls/vtec...
ok i bought a b18a1 the other day cuz i wanna stay with obd0 and i wanna do a N/A motor. and i know i need new mounts and wiring and all that stuff... but i was wondering what kind of aftermarket pistons i could get and rods. stock ls pistons give u a bad CR and not much valve clearance and the ls cranks are a longer stroke im going to go take it and get it bored and honed but im only going 2 over stock. Also i was wondering can you use any v/tec head i wanna go with a b16 head but does it have to be obd0????/ thanks for your time
#2 | |||
The Kicker of Elves.
Two what, over stock?
Don't forget that you need a VTEC oil pump. Use CTR pistons.
Don't misinterpret what I say. Quote:
i thought about boring it out to a 81.50 but i donno thats what i ment to say....ok those r b16 pistons right......and also could i use any b16 head or does it have to be a obd 0 head and with a ls distributor work????
#5 | |||
Ah, say 20, .020", or .5mm over.
![]() CTR pistons are B16B pistons, don't remember the code off the top of my head.
#7 |
ok.. i understand everything else.. its just im lost on choosing what pistons to you....... i dont really understand it.... can i use b16 pistons and stock ls rods or would i have to get aftermarket ones and would i have enough valve clearance to use bigger cams??? thats the whole part im lost on... cuz i wanna do a all motor ls/vtec... and i want my CR around 10. or so.....
#8 |
HS Troll...And Mod
Ride: 2001 Honda S2000
youd have to modify the ls rods. i think the pct/p30/pr3 pistons all use a bigger wrist pin.
If you PM me with tech questions, you better have a link to the thread in your PM. Need engine Components? -- Call Us. Tell them Fritts sent you and they will cut you a deal you will have to hear to believe. |
#9 | |||
Here, play around with the compression calculator. ZealAutowerks - Honda Compression Calculator
#10 | |
HS Troll...And Mod
#12 |
You do not have to get specifically a VTEC oil pump.All obd2 oil pumps are the same.Its the obd1 and obd0 ones that are different.If you want to look it up you can,go to a autoparts store and check the part numbers on obd 2 dohc vtec oil pumps and they are the same.CRV,99-00 Si,GSR,LS,type-r all of the obd2 ones are the same.No need to spend a shitload on a dohc vtec oil pump that people sell for alot when you can use another one thats the same and cheaper.
#13 |
ok i got another question... i have a b16a crank shaft i was wondering if i can put that in a b18a1. if i can do i just use the b16 main caps????? and i got my oil pump off a b16 and a water pump... now i just need the pistons head and tranny
#14 |
Grand High Wizard
you can use a b16 crank but you'll lose displacement and compression, so big loss of power there, and even if you bore it out the maximum you can get with a b16 crank in a b18 block is 1840cc thats at an 87mm bore
| anyone do a JDM d15b in to a 92 civic/ also swap info | 92civy | HYBRID -> EG-EK / DC | 1 | 09-07-2006 07:23 PM |
| do help me identify my accord type please | fatblack4 | Members' Lounge | 1 | 09-05-2006 10:20 AM |
| Spoon civic and Spoon Teg info | theB16tegguy | Members' Lounge | 8 | 01-16-2004 08:16 AM |
| Need some help with Trim Names | YangpaNemsay | General Tech and Maintenance | 7 | 08-31-2003 04:43 PM |
