when i turn my ignition switch on my engine check light doesn't come on, the only light that comes on is the handbrake and oil light... my is not starting up and my ecu doesn't blink either if you know or might think you know could give me any suggestions and let me know...
My name is Byron.
Ride: `89 DX Hatch w/JDM B16
Check all your fuses, under the dash and in the engine bay on the shock tower, there is a fuse for the ECU in the shock tower block. If that fuse is blown you wont have any power to the ECU, thus not giving you the short blip when you turn the key to the "on" postion.
Dont PM me with tech questions. I will not answer them. Looking for a P28 and B-series turbo parts, PM me. |
Ride: 88 Honda Civic HB
Bad ECU would still crank.
If the starter is getting signal, probably just a bad/dead battery or bad connections(ground/power). If it's not getting signal, most likely the ignition switch/cylinder.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
#5 |
i checked all the fuses... how would i check if my ecu is bad or not... and the motor turns over but i have a push button start that has direct power to the starter... could it be my ignition switch cylinder, thats the whole reason why i made a push button start because it was'nt working...
#9 |
Hondaholic
Ride: 91 hatch z6/ 98 coupe z7
main relay or (alt) fuse under dash. Test your fuses with a test light or multi meter. If your main relay is bad your fuel system will not operate and you will not get spark.
Proper ignition system evaluation begins by answering three basic diagnostic questions: 1. When you turn the ignition switch to ON (not START), does the Check Engine Light (CEL) come on and then go off after 2 seconds? If not, the problem is with the ACG (ALT) (S) fuse, in the under-dash fuse/relay box; ECM . 2. When the CEL goes out, (in your case it never comes on) do you hear and/or feel the Main Relay "click"? If not, repair or replace the Main Relay. 3. During the 2 second interval that the CEL is on, do you hear the fuel pump in the gas tank run? If not, check the fuel pump. If the CEL does not go out, most Civics will not spark and the fuel pump will not run. That's why we begin our diagnosis here. Remember, the Main Relay actually contains two individual relays. One relay is energized whenever the ignition is on, which supplies battery voltage to the ECM, power to the fuel injectors, and power for the second relay. The second relay is energized for 2 seconds when the ignition is switched on, and when the engine is running which supplies power to the fuel pump. Next, test all under-hood and under-dash fuses with a test light or multi-meter. Using a test light or multi-meter is faster, more accurate, and eliminates the possibility of replacing a fuse in the wrong |
#13 |
Handy Manny ;)
Ride: 91 Crx HF_ 83 Rx7 Gsl_02 Accord EX
ya.
take the ecu out. throw it on the ground, put it back in, if it works its good, if it doesnt its been a bad ecu. and doesnt deserve to live. therefore u take it to a bridge thats over water, wish for a better ecu and throw it backwards over ur shoulder. then, u go online, and buy a new one. works everytime |
