Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
Members have access to more features and see fewer ads! It's free, what are you waiting for?
D15 Cooker
Ride: not a dam thing at the moment...
Thanks for reading everyone! Im attempting my first engine swap by myself on a 91 CRX HF I have had the car for a few years. And after a really hard day of driving last summer the car overheated, melted the timing belt cover, and eventually the lower half locked up mid stroke....It was a nasty engine death
my best guess is that maybe one of the crankshaft bearings went bad... Ok, I have done a lot of searching, and reading. But i would just like to make sure i am getting the right things. ![]() I started on the project today, Old D15B6 (i think ) is half out of the car. Top end out all i need to do is disconnect the trans. I am hoping to be able to use the transmission i have. From the Gold sticker on the casing, it says its an L3-1XXXXXX.Am i correct thinking that this will mount to a ODB0 DOHC ZC? And will i need to use the ZC ECU? wiring harness? etc.... Im not a honda expert by any means. Just trying to gather as much information as possible. |
the HF transmission will bolt right up to the DOHC ZC engine - the gearing in the HF transmission is really long and you might want to look into finding an Si transmission in order to get the most out of the ZC - you use the HF engine harness on the ZC and rewire the distributor connector or buy a distributor adapter from Rywire - Rywire - Online Store - the best ECU to use with the DOHC ZC is the JDM PM7 - next best would be 88-89 (not 86-87) Integra PG7 - you could also use the 88-91 CRX/Civic Si ECU, PM6
ZCspeed Racing |
#3 | |
D15 Cooker
![]() I actually have the pdf from ZCspeed about how to do the distributor connector wiring from HF to ZC. Thanks again ![]() Im going to open a new thread about my build today. With pics, and my questions included. As I am sure I will still have more. Thanks for taking the time to respond. And helping someone new ![]() I hope to give the readers of hondaswap something to make them smile. An old honda coming back to life, instead of being scrapped or chopped to pieces. |
| B18C1 Swap Questions and Gauge/Cluster Swap Questions | |Chaz| | HYBRID -> EG-EK / DC | 14 | 03-21-2008 11:36 PM |
| swap questions | kricket3000 | Civic and CRX - EF | 31 | 12-02-2006 04:36 PM |
| crx h22 swap questions | -94-AccordH22 | HYBRID -> ED-EF / DA | 11 | 08-09-2006 07:05 AM |
| 2 Swap questions | dwn2low | HYBRID -> EG-EK / DC | 9 | 01-29-2004 09:26 AM |
| Questions About Swap | 94civicex | HYBRID -> EG-EK / DC | 2 | 03-15-2003 10:53 AM |
