91 crx si b16a bogging code 6,9,10
Old 11-04-2009, 01:44 PM   #1
Greenhorn
Ride:  91 crx si b16a
Rep Power: 0 91Sib16a is on a distinguished road
Send a message via AIM to 91Sib16a myspace  FaceBook
Question 91 crx si b16a bogging code 6,9,10
hey i got a 91 crx with jdm b16a obd0 with pw0 ecu it's throwing code 6 which i know is my coolant temp sensor and 9 which is my cyp sensor and code 10 which is my iat sensor. changed the cts and iat but the car still bogs sometimes but not all the time i know you cant change the cyp sensor so should i just change the dizzy? anyone have any other ideas? it seems like i have no power know and its throwing the cyp dizzy code still.
Thanks,
Andrew
91Sib16a is offline   Reply With Quote
Old 11-06-2009, 03:53 AM   #2
Rep Power: 0 eman13 is on a distinguished road
mine use to do that it was my cam sensor, sometimes it would bog down or wouldn't rev high enough.
eman13 is offline   Reply With Quote
Old 11-06-2009, 10:01 AM   #3
Greenhorn
i changed the dizzy and still same problem then noticed the engine timing is off by like 3 teeth on the crankshaft pulley resetting the timing now hopefully this will stop everything i was told the timing being off can throw the cyp sensor also.
Old 11-06-2009, 11:38 AM   #4
Greenhorn
timing set still throwing code 6,9,10 but all the power is back and no more bogging! any ideas anyone :conf used:
Old 11-08-2009, 02:20 PM   #5
91_stylin_civic's Avatar
Ride:  91 civic hatch w/b16 and 91 civic hatch project car
Rep Power: 8 91_stylin_civic has a spectacular aura about91_stylin_civic has a spectacular aura about
did you clear the codes after you reset the timing?
91_stylin_civic is offline   Reply With Quote
Old 11-08-2009, 02:41 PM   #6
Greenhorn
Unhappy
ya i did. think its my harness ecu is good all wires on the ecu are right so gonna try the harness
Old 11-17-2009, 02:38 AM   #7
Ride:  civic/tegra
Rep Power: 1 kidkg24 is on a distinguished road
Send a message via AIM to kidkg24
my 1990 civic with a 1998 ls swap was doing the same thing with codes 3,7,9.. I changed everything with parts from another car i had, and still same codes... I then said forget the head ache, and went to the auto parts store.. Bought some 60 ft. wire. Ran New wires from the ecu to the plug where the engine harness hooks in.. checked for any breaks in the engine harness. When I ran the new wires, and taped them up so the look all nice. went on my first test drive. " NO MORE CODES, AND NO MORE BOGGING" i'm going to call it a wiring problem.
kidkg24 is offline   Reply With Quote
Need Help--Crx w/ b16a bogging at idle mrme HYBRID -> ED-EF / DA 9 04-23-2008 10:10 AM
Help code 23 on my 92 si with b16a nolimitlowrider ECU's, Electronics, and Tuning 4 07-05-2007 04:58 PM
Need help code 9 in my hf w/b16a xips(86CRXSI) HYBRID -> ED-EF / DA 5 01-06-2007 04:03 PM
ELD Code >> JDM B16A into EG5 VTEChnique ECU's, Electronics, and Tuning 0 05-01-2005 07:26 AM
B16a Bogging Like A Mutha! mattcalica Engine Building 3 01-24-2003 07:40 PM
