Ride: 91 ef si b18c, 90 ef si zc15, 2006 gsx-r 1000, 2008 nissan armada
I was wanting to know how much horsepower I have and ft pounds torque...I have a 91 si ef and I have a b18c with itr pistons and I also have the itr intake manifold...could use some help thanx
Token GM Guy
Ride: 91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
I cant be for sure without smelling your cars exhaust fumes while you turn on your left blinker, but if I had to guess, I'd say roughly 9,645,897.33 cubic tons!
Si vis pacem, para bellum There are no stupid questions, but there are a lot of inquisitive idiots. TWIN Turbo V8 CRX |
#4 | |
!!YTINASNI
The amount of hit points your car has depends on what type of armor you have on it, as well as any item enchantments. Do you have HP rings or DPS rings?
#5 |
Ride: JRSC B20/vtec DC, Nissan Xterra SE
lol smartass ^
dude we arent magic, you give very little information and expect a number amount? the b18c is rated at 180hp from the factory (at the crank). with higher compression and bolt ons you will be a little more than that. if you give us an exact mod list maybe i could make a guess. is the car still on a stock ecu? if you get it dyno tuned it will not only make more power, but you will also know how much power it has ![]() Last edited by mdpsEG; 11-07-2009 at 11:50 AM. |
#7 | |
!!YTINASNI
A jdm b18c makes around 180hp, 126tq.
The full on ITR has more aggressive cams, a better flowing head, a better tune, and better flowing exhaust, and it only makes 190-200. So assuming your motor is freshly built and has solid compression like a new motor would, and is running in absolutely tip top shape, I would guess something like 185 at the crank. but this is just a guess. You could probably pry out another 10hp with a good tune. __________________
#8 |
Token GM Guy
More than a B16, less than a K20. Good enough?
#9 |
Well I have the jdm b18c specR with itr pistons itr intake manifold p72 ecu with a aem cold air intakeintake...thanx
#10 | |
!!YTINASNI
Are you retarded? Mentally challenged?
Why would you say you have the b18c "specR" with the type r pistons and IM? You should have type R pistons, rods, crank, block, head, valves, valve springs, cams, blah blah, its a fucking type R motor, you should have type R everything. And why the fuck are you running it with a GSR ecu? __________________
#11 |
Well I just got the car 2 days ago and this is what the guy told me...he didn't even know it was a type R...I found out it was a type R the second I saw it and homeboy didn't even know what he was sitting on...what do you recommend I do???
#12 | |
SOHC on this!!
Get a chipped ECU and tune it.
#13 |
Also my 91 came with skunk 2 pro c series dampers....I have a 90 si hatch with blue koni adjustable shocks and eibach sportline lowering springs...which r better
#15 |
if it has a complete itr head and has itr pistons then it is essentially a type r engine. the p72 is the gsr computer and its not running your car right... unless the computer has been modified.
#17 | |
I'm just EF'n..
Ride: 91' civic Dx
pretty klean.. Def. get it tuned.. __________________
DONT FORGET TO REP A BROTHER. ![]() XBL Gamertag: SIROSKERCHIEFS (COD4,HALO 3,COD: WaW,soon to come COD4:MW2) 91 CIVIC HB DX:Stock B16a swap,lowered,sittin on slipstreams.
#19 | |
SOHC on this!!
Chip a P28 ECU, or get a Hondata.
#21 | |
SOHC on this!!
Both are tuneable ECUs. Hondata is more expensive than a chipped P28 but both do the same job. Search it up on eBay or something. You can't just get a P28 ECU, you have to get it chipped after because it's a stock computer for a Civic.
#23 |
look before you even worry about how you are going to tune your car.... you should really just find someone (or a shop) in your area that knows how to tune. ask what them what they are familiar with, they will be able to get you what you need. you can chip and tune the ecu you already have. if i was you i wouldnt buy anything without finding someone to actually do the tuning first.
| Jdm 1996 acura integra civic b18c gsr engine b18c motor | RSS-Bot | Auctions | 0 | 03-12-2009 11:17 AM |
| Jdm 1996 acura integra civic b18c gsr engine b18c motor | RSS-Bot | Auctions | 0 | 02-24-2009 12:50 PM |
| Jdm 1996 acura integra civic b18c gsr engine b18c motor | RSS-Bot | Auctions | 0 | 12-29-2008 03:03 PM |
| Jdm 1996 acura integra civic b18c gsr engine b18c motor | RSS-Bot | Auctions | 0 | 12-22-2008 09:50 AM |
| Jdm 1996 acura integra civic b18c gsr engine b18c motor | RSS-Bot | Auctions | 0 | 12-05-2008 01:17 PM |
