91 honda crx hf help
Closed Thread
Old 04-15-2008, 03:19 PM   #26
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 98 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
Originally Posted by OKCZombie View Post
I personally like DOHC ZC swaps in a crx but swap it all out to a d16a6 - convert it to SI - still fairly cheap can have some fun,
indeed..do the d16a6,,awesome gas mileage and still has some pep to it,,and when you feel the need for more,,do a home turbo,or swap a z6 head
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now
Old 04-15-2008, 04:50 PM   #27
Rep Power: 2 cREX is on a distinguished road
i can get a d16z6 vtec head off of a 92 ex civic and a crx si ecu. but do i really need the si ecu , im confused on what i need to do to run this vtec head.
cREX is offline
Old 04-15-2008, 04:52 PM   #28
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
you have to match the head to the ecu your going to use if you use a 92-95 d16z6 motor you need a 92-95 si or ex ecu aka p28
AHHVTEC is online now
Old 04-15-2008, 08:33 PM   #29
ic ic .. well i got a buddy that has a crx si ecu that he gave to me.. just not sure if i wanna do a vtec head or not.. cause it sounds like its gonna be more$$$ than i feel like spending right now.
cREX is offline
Old 04-15-2008, 10:05 PM   #30
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 150 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
The CR-X Si didn't have VTEC, therefore that ECU will not run a VTEC head correctly...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
BrutalB83 is offline
Old 04-15-2008, 10:34 PM   #31
HONDA HUMPER
93AccordEX's Avatar
Ride:  A Spaceship!
Rep Power: 10 93AccordEX is a jewel in the rough93AccordEX is a jewel in the rough93AccordEX is a jewel in the rough
myspace
Wet sand and clear coat for the time being. my old 89 lude looked like that. we wet sanded it and put a clear coat on and it looked great kinda pink but pimp
Another thing i wen to buy my 90 civic hatch and i got the guy down to 500. so i said ok i wanna buy it. then he gave me the key and i keyed the shit outta the car. BONDO MADNESS!!!! i took the car for 375
Originally Posted by BrutalB83 View Post
Awww...I thought this thread was going to be about drag queens...
My Projects:
C
ore support on a 96 Nissan Sentra
My CB7 Build (Taking forever to get started)
93AccordEX is offline
Old 04-16-2008, 02:47 AM   #32
yea i know the si crx does not have vtec. i was just saying a buddy gave me a di crx ecu and if i decied not to go with a vtec head than i can run the ecu, but its a 91 crx ecu so does that mean i need a 91 nonvtec head?
cREX is offline
Old 04-16-2008, 04:21 AM   #33
Ride:  91 integra with ls/vtec...
Rep Power: 8 ls/vtechatch91 is on a distinguished road
my buddy did a zc/vtec (mini me) in his 90 hf crx and he ran a pg7 ecu and toggled his vtec... that motor was really quick stock JE pistons and the head shaved to shit.. with a alot of bolt ons... but ya i know he should of converted it to obd1 but he no longer has the car anymore. traded it for a eg hatch,, but i'd go with a mini me
ls/vtechatch91 is offline
Old 04-16-2008, 09:42 AM   #34
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
im not sure if you can do this but,,,im sure someone will chime in,,,
run a d16a6 head on it...usually minime's are vtec heads on non vtec blocks...
but seriously you can get a complete d16a6 for less than 500
GOOD FAST CHEAP,
Old 04-16-2008, 10:34 AM   #35
If i run a d16a6 head, what all do i need to run it? from ecu to harness..if its going to end up costing more than i want to spend right now to run the vtec head then im prolly just going to stick with a nonvtec head and run the crx si ecu. im not trying to spend a shit load just cause of the fact that this motor will be swaped prolly next winter. i just want something thats good on gas and is quick.
cREX is offline
Old 04-16-2008, 10:59 AM   #36
Carb'd honda's rule
Ride:  1987 CRX base model with HF transmisison
Rep Power: 0 wlee598 is on a distinguished road
Hey cREX when you find out what motor you want to swap in do you think you're going to sell that hf engine? because I could totally use that 50+ mpg.
wlee598 is offline
Old 04-16-2008, 02:29 PM   #37
Rep Power: 0 wingtip4 is on a distinguished road
At the risk of seeming anti-hotrod, why not just drive it awhile and get the 50 mpg?
wingtip4 is offline
Old 04-16-2008, 04:03 PM   #38
BrutalB83's Avatar
myspace
We get questions like this all the time. Honestly I don't see the point of spending any money on it now if you're just going to swap it out for another motor later. Do you just have no patience or what? Why would you spend any money at all on something if it's not what you really want? Why would you waste money on some temporary modification when you could just save it towards what you actually want and have it that much faster?
Don't waste any money on a temporary swap or temporary build, just drive the thing for now and enjoy the 50 mpg, and save your funds towards the engine you really want to have...
Old 04-17-2008, 12:57 AM   #39
well tonite i pulled the oil pan off and checked the rods.. 2 of the rod barings was fucked to the point one of them messed the crank up .. so much for a easy fix. my buddy is helping me figure out what i should do.. cause im not trying to spend alot.. moving into an appartment in 2 months for college so money is tight .. and the reason i got the car is to drive from ky to tn. idk im gonna sleep on it and hopefully figure out what to do. tomorrow we are pulling the motor and trans out and i will have a new update then..if you guys got any ideas on what i should do "keep in mind im not trying to spend alot" then post it up. thanks
cREX is offline
Old 04-18-2008, 07:51 AM   #40
quick question.. i wanted to put a 16v head onto my d15b6 but i started to ponder the fact that there is to resesed spots on each cylinder, but if i put the 16v head on there will i need to put pistons in there that have 4 resesed spots in each?
cREX is offline
Old 04-18-2008, 02:44 PM   #41
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
^i dont think so..im sure there is enough clearance,,but why put a 16v head on a block tha has a fucked up crank??
sounds to me like its time to put a d16a6 in it
GOOD FAST CHEAP,
Old 04-18-2008, 09:48 PM   #42
yea im going to see if i cant get the crank polished out cause its not to too bad. thats an option tho.. kinda just throwing around ideas on to swap it and what with and not spend a shit load.
cREX is offline
Old 06-19-2008, 01:35 PM   #43
Handy Manny ;)
hope801's Avatar
Ride:  91 Crx HF_ 83 Rx7 Gsl_02 Accord EX
Rep Power: 42 hope801 has a brilliant future
holy fuhhhhh!
im angry at u.
i got my hf for 1k and doesn't look half as descent as urs. fuhhhh!
Originally Posted by teggyguy View Post
3 some with ef's lady and taco's is what you get when you die and go to heaven.
hope801 is offline
Old 06-19-2008, 01:49 PM   #44
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 234 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace
way to be 2 months behind
DO NOT PM ME WITH TECH QUESTIONS!
Originally Posted by Celerity View Post
Nothing says class like Willie Nelson on your pussy.
MY For Sale thread
eg6sir is online now
Old 06-19-2008, 02:36 PM   #45
Handy Manny ;)
hope801's Avatar
i just found the thread 2 months behind
hope801 is offline
Closed Thread
Forum Jump
Uberdata honda hacking & tuning JDMEG-6 ECU's, Electronics, and Tuning 3 01-25-2007 07:33 PM
Honda Parts Catalog hpcuser General Tech and Maintenance 15 11-13-2006 01:13 PM
1993 Honda Accord LX $1800 OBO! Maryland/VA/ D.C. verothacamaro Vehicles: For Sale/Trade/Wanted 5 09-07-2005 02:22 AM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
Honda Jet's "Secret" Flight Airjockie Members' Lounge 25 12-19-2003 03:45 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
