93 Civic HB O2 sensor help needed
Old 10-04-2006, 12:40 PM   #1
Ride:  93 Civic HB
Rep Power: 0 Davem is on a distinguished road
Default 93 Civic HB O2 sensor help needed
I have a 93 civic cx hb with a b18b in it. Everything is smooth but the check engine light is giving me a 41 code. I am running the cx harness.
I hooked up the O2 sensor following the directions from this site for a 1 wire to 4 wire but am still getting a 41 code. I am using a p72 and a bosch 4 wire.
Any feedback would be great. Thank you.
Davem is offline   Reply With Quote
Old 10-05-2006, 04:59 PM   #2
Ride:  93 Civic HB
No one has any ideas on this? Here's what we followed from the swap articles section:
Wires on 4 wire O2:
WHITE: Signal Wire
GREEN: Signal Ground
2 BLACK: Both black wires are the heater circuit wires.
Using a P28 ECU (and should work for most obd1 ecu's with 4-wire controls)
Run O2 Sensor signal (white) To D14
Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control (black) to A6
Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
(you may mix up the black wires... if car dies after it is warm/10-30 seconds, that's the first thing to swap over and troubleshoot.. theres no way to tell one from the other by looking at them)
LOTTA CIVIC SOHC PARTS *CHEAP* lil_red_si Parts: For Sale/Trade/Wanted 8 02-20-2006 11:39 AM
NEEDED - Interior Trim Piece for 94 civic Cashizslick Parts: For Sale/Trade/Wanted 2 05-04-2004 11:38 PM
needed: rear lca's for 5th gen civic seanjuan Parts: For Sale/Trade/Wanted 4 04-27-2004 01:06 PM
H22a Into 92 Civic Information Needed akouznet HYBRID -> EG-EK / DC 8 04-24-2003 03:03 AM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
