after market shift light
Old 03-31-2008, 01:47 PM   #1
Ride:  1989 HONDA CRX DX
Rep Power: 0 89hdarex is on a distinguished road
Default after market shift light
I have a shift light that i want to install. does anyone know where i should hook it up to??
i want it to come on at 6K, and i have no idea how to make it work and come on at 6K.
Can someone please help me?????
"RICER"
89hdarex is offline   Reply With Quote
Old 03-31-2008, 01:54 PM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 160 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
well theres 2 types of shift lights one kind takes pills that control when the light comes on the other has a dial on the back that you set. so depending on witch one you have either set the diaa to 6,000rpm or put a 6000rpm pill in.
Old 03-31-2008, 05:59 PM   #3
it has a pos and a neg wire on the back, it looks like it was on a big tach. is there anyway i can get it to work the way i want or is it no good??
"RICER"
Old 03-31-2008, 06:00 PM   #4
HS TECH
AHHVTEC's Avatar
well if it dont have a place to put pills or a dial on the back im thinking its no good
Old 03-31-2008, 06:07 PM   #5
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 92 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
you will need an rpm activated switch..then you hook up the rpm switch,,red to pos. and black to neg, there should be another wire coming from the switch you put the red(pos) to the wire coming out of the switch and the black(neg) to a ground
oh and there should be a wire that intercepts a signal from the tach,that goes to the tach wire/green wire from the dizzy,this rpm switch will run off the "pills" that ahhvtec mentioned
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX
R.I.P BEN LEE2/24/08 we love and miss you
R.I.P Rex 8/18/08 coolest dog ever!!!
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 03-31-2008, 06:11 PM   #6
żUnKnOwN?
INJEN78's Avatar
Ride:  91 CRX si
if it was on a tach already then what i just wrote might not work,,but give it a try!!and in between the red wire on the light and the wire on the switch you should put a resistor,or fuse...
GOOD FAST CHEAP,
Forum Jump
What light is this RIT Civic ECU's, Electronics, and Tuning 0 01-17-2004 10:23 AM
how to install a autometer shift light on ek? ajmj HYBRID -> EG-EK / DC 2 08-08-2003 12:00 AM
Vtec Light Boodussi808 Members' Lounge 3 05-16-2003 09:35 PM
shift light solRNY ECU's, Electronics, and Tuning 2 11-13-2002 02:35 PM
Autometer shift light and pills SolReaver Parts: For Sale/Trade/Wanted 2 10-28-2002 03:50 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
