aftermarket steering wheel..no horn?
Old 07-09-2008, 03:45 AM   #1
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
Rep Power: 17 HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
Default aftermarket steering wheel..no horn?
i installed a momo steering wheel on my 90 civic hatch..is there a way to keep the horn? i had to disconnect the copper tab on the colomn cause it would make contact with the hub adapter and the horn would go off when i made a turn,, any suggestions?
admit it..your a ricer....
90 si hatch jdm d15b swap(done)
91 dx hatch b16 swap (in progress)
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
stage 3 act clutch ftw
HATCHET_HONDA is offline   Reply With Quote
Old 07-09-2008, 04:22 AM   #2
Bkkfarang's Avatar
Ride:  95eg extreme single cam / 06jazz hks turbo soon/
Rep Power: 11 Bkkfarang is a jewel in the roughBkkfarang is a jewel in the roughBkkfarang is a jewel in the rough
strange issue . normally you cab just bend the tabs connecting the horn wire to avoid contact
Bkkfarang is offline   Reply With Quote
Old 07-09-2008, 04:45 AM   #3
scottie fizzle
ive tried that.. but in a day the cotact tab is touching the middle of the hub again and the damn horn is goin off
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-09-2008, 04:54 AM   #4
Bkkfarang's Avatar
touching the middle ? could th wire be too short ?> and when you turn its getting pulled tight ?
just a thought !
Old 07-11-2008, 01:45 AM   #5
scottie fizzle
just a thought !
the wire isnt the problem its the copper contact tab..ok, the factory wheel has a copper ring on the bottom that makes contact for the horn..well the new hub is ALL metal so not only does it touch the bottom as its supposed to it also touches on the center of the hub when the wheel is turned..thinkin of just unhookin the tab and sayin fuck it
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-11-2008, 11:19 AM   #6
autox 89 dx's Avatar
Ride:  91 SI SOHC ZC mini me
Rep Power: 7 autox 89 dx will become famous soon enough
fuck a horn thats how I roll
autox 89 dx is offline   Reply With Quote
Old 07-11-2008, 11:32 AM   #7
universal logic protocol
whiterabbit06's Avatar
Ride:  99 VW GTI 07 Jeep Compass
Rep Power: 81 whiterabbit06 has a reputation beyond repute
whiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond repute
Send a message via AIM to whiterabbit06 Send a message via MSN to whiterabbit06 Send a message via Yahoo to whiterabbit06
This is my horn:
Originally Posted by TurboMirage View Post
i live my life one billable hour at a time. for that 60 minutes or less, im expensive.
90 Civic Hatch <= Sold
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now
07 Jeep Compass
If you ever find anything I write usefull please leave rep.
Rebuilding a Transmission
http://www.the-whiterabbit.com
whiterabbit06 is offline   Reply With Quote
Old 07-11-2008, 01:23 PM   #8
scottie fizzle
yep.. thats what i figured... no one i know has a horn that works either
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-22-2008, 05:20 AM   #9
scottie fizzle
just an update....i recently chucked that shitty ebay hub adapter and have installed a quality momo brand hub. whattya know..my horn works fine!! has been for like 5 days now...sometimes you get what you pay for i guess
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 07-22-2008, 05:30 AM   #10
Bkkfarang's Avatar
glad you got it fixed , but your right at times you do get just what you pay for
Old 07-22-2008, 05:39 AM   #11
scottie fizzle
yep.. the new hub was like 80 bucks but it looks alot better now and the damn horn works! well worth it indeed
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Tags
aftermarket, horn, hub, steering, wheel
How To: Install an aftermarket steering wheel. Andrew Civic and CRX - EF 61 04-03-2009 04:17 AM
aftermarket steering wheel installation nocturnal_pinoy Civic and del Sol - EG and EK 3 10-06-2006 01:29 AM
How to wire the horn for a Non-SRS steering wheel civicious General Tech and Maintenance 0 05-12-2005 07:32 PM
Aftermarket Steering Wheel: For Offroad Use YangpaNemsay Body / Exterior / Interior / Cosmetics 3 12-22-2004 02:37 PM
Momo Steering Wheel, Horn? QuicSilver ECU's, Electronics, and Tuning 1 02-06-2003 03:07 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
