auto shifter locked after ecu swap
Old 03-13-2008, 06:18 PM   #1
goose2's Avatar
Rep Power: 5 goose2 is on a distinguished road
Default auto shifter locked after ecu swap
ok i finally have the dx running i did a dx to zc swap sohc.I had to swap out the ecu to a multi port zc ecu and now the new ecu is blinking 9 times no 1 cylinder position.and the auto tranny shifter will not move after its started.and man is it blowing out some white smoke.help please.
team loud & clear
2007 stock 0-600 world champion usaci
0-600 stock world record holder usaci
goose2 is offline   Reply With Quote
Old 03-14-2008, 05:59 PM   #2
SOHC on this!!
GlassHeadlights's Avatar
Ride:  '91 CRX Si and '90 Civic Si
Rep Power: 65 GlassHeadlights has a brilliant future
if your car is a 90-91(on the shifter there will be a key hole and words saying "shift lock release") then your ecu for the zc is problay a standard transmission ecu. if u r running auto trans you need a automatic ecu.
but if your car is a 88-89 i have no clue why it is locking.
if your car is a 90-91 try sticking a key down the "shift lock release"hole and try to drive it. good luck
GlassHeadlights is online now   Reply With Quote
Old 03-14-2008, 10:24 PM   #3
goose2's Avatar
well i took the pin off of the shifter switch and it works fine.ya its a 91.its still idleing high though.i have turned the dizzy all the way forward and turned the idle screw all the way in and it still is setting on 1700-1900 rpm at idle.
team loud & clear
Old 03-15-2008, 12:24 AM   #4
SOHC on this!!
when i did my auto to standard tranny swap, my car ran like crap with the auto ecu and manual tranny. it idled high and went up and down between 1200 and 2500 rpm, again if you are running a auto trans you need a zc automatic tranny ecu, it may be hard to find. then your shifter should unlock normally.
Old 03-15-2008, 04:03 AM   #5
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 215 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
White smoke=blown head gasket fix that before you worry about anything else.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 03-15-2008, 10:35 AM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 213 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
either a headgasket or warped/cracked block or head.def woory about that first
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 03-16-2008, 09:25 PM   #7
goose2's Avatar
thanks for the heads up.i am on the search for the auto ecu.
team loud & clear
Old 03-17-2008, 10:20 AM   #8
goose2's Avatar
the ecu i have is #37820-ps9-a50.what # would i need for an automatic?
team loud & clear
Old 03-19-2008, 12:47 AM   #9
SOHC on this!!
that i cant help you out with sorry
Old 03-23-2008, 02:40 AM   #10
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 5 monotech909 is on a distinguished road
do you have a DOHC zc or single cam ZC?
Who did your wiring? could be you have a wire reversed I have seen this happen alot to people who don't wire in there harnesses correctly. The smoke could be due to the CPS code you are throwing. If you wired the harness in correctly you shouldn't have any check engine lights on.
monotech909 is offline   Reply With Quote
Old 03-23-2008, 02:42 AM   #11
Got V-tec?
Ride:  Whip!
what distributer are you using?
7 wire round plug?
5 wire square plug?
If you have a DOHC Zc engine and using Si round plug 7 wire you will need this adapter.
Old 03-23-2008, 05:22 PM   #12
goose2's Avatar
its a sohc.and i changed my square dx harness into a round si harness.5 to 7 with the 2 new wires from the ecu.i just need to find an automatic tranny ecu.a pm6,pr4 ect.obdo.
team loud & clear
Old 04-04-2008, 05:51 PM   #13
goose2's Avatar
ok i bought a pg7 ecu and it runs great.but my automatic shifter still will not go out of park.and the ecu is blinking 19 times.lock up control solenoid valve a/b (a/t)
team loud & clear
96 Honda Accord w/ H22 Auto Swap 96Hybrid Accord 5 02-09-2008 02:06 AM
Help-2000 auto 4 dr. civic lx needs engine/tranny swap murphy8043 Engine Building 1 02-06-2008 01:06 AM
auto to manual conversion d112crzy HYBRID -> BA-BB /CA-CD 0 09-13-2006 11:27 AM
Auto swap anyone? bigmikerican HYBRID -> EG-EK / DC 14 11-28-2005 08:29 PM
Best Engine Swap With An Auto Trans? develishex HYBRID -> EG-EK / DC 9 06-19-2003 02:57 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
