axle nuts!!
Old 04-24-2008, 01:18 PM   #1
my cars go fast
SLOWdelawareEG's Avatar
Ride:  ED8
Rep Power: 10 SLOWdelawareEG will become famous soon enoughSLOWdelawareEG will become famous soon enough
Default axle nuts!!
doing my swap last nite/today, and cant get either axle nut off. im using a 1/2" breaker with a 3 foot cheater on the end! the whole car is wobbling and moving and bouncing up aand down but they wont budge. thought about cutting them off with a grind wheel. any quick suggestions?
SLOWdelawareEG is offline   Reply With Quote
Old 04-24-2008, 01:19 PM   #2
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 215 nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
did you pull the tab out on the nut?
nootrac22 is offline   Reply With Quote
Old 04-24-2008, 01:21 PM   #3
AHHVTEC's Avatar
Rep Power: 268 AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
check for the tab like he said,,and then set the car back on the ground to break it free
Old 04-24-2008, 01:22 PM   #4
Jizared97's Avatar
Ride:  97 ex coupe, 89 240sx
Rep Power: 44 Jizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant future
Send a message via AIM to Jizared97 myspace
I used a chisle and cut mine.
=D
Also used a torch
Jizared97 is offline   Reply With Quote
Old 04-24-2008, 01:28 PM   #5
my cars go fast
Ride:  ED8
this isnt my first rodeo. thats not the issue
Old 04-24-2008, 01:29 PM   #6
nootrac22's Avatar
Also if you have someone to help, you can apply presure with the breaker bar and have them hit it with a sledge hammer (kinda like an impact wrench). heating the nut could help also, but don't use propane, if you dont have access to oxy/acetelen(sp), use mapp gas. it's much hotter than propane.
Old 04-24-2008, 01:31 PM   #7
AHHVTEC's Avatar
oh and make sure the tire are back on it before you set it on the ground to break it free
Old 04-24-2008, 01:33 PM   #8
my cars go fast
Ride:  ED8
i have acetylene. give me a few mins to go try this. i think im going to utilize the torch along with the giant breaker bar impact method. thanks fellas. wish me luck
Old 04-24-2008, 01:34 PM   #9
Rep Power: 4 ACME CRX is on a distinguished road
Yea I had that problem with my CRX. I broke off the screwdriver tip trying to push the tab out. I tried to load it with BP Blaster then force it over. Didnt work. I applied heat to it then let it cool back down. Put it back on the ground, used a 3ft cheater bar, and had the fattest friend I could find stand then jump on the bar. That worked for me. My next attempt was going to be an air chisle. They always work... but usually you have to replace something else too because you damage it.
ACME CRX is offline   Reply With Quote
Old 04-24-2008, 02:47 PM   #10
..is grounded.
dacheat's Avatar
Ride:  '84 buick (rusted)
Rep Power: 257 dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
dacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond reputedacheat has a reputation beyond repute
Originally Posted by ACME CRX View Post
...used a 3ft cheater bar, and had the fattest friend I could find stand then jump on the bar. That worked for me.
exactly. ps there's no way on the planet i coulda gotten these off my car by myself. talk about pissed. thank god for he-ain't-heavy-he's-my-mechanic.
marco....
dacheat is offline   Reply With Quote
Old 04-24-2008, 03:20 PM   #11
my cars go fast
Ride:  ED8
got em. it took acetylene and me standing my skinny ass on a 4ft bar and jumping up and down.
Old 04-24-2008, 03:21 PM   #12
my cars go fast
Ride:  ED8
thanks for the help
Old 04-25-2008, 12:27 AM   #13
Rep Power: 11 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
before i bought my composite impact (1000ft. lbs) i used to put the car on the ground, get my 1/2" breaker bar, and put my jack handle over it. that made the length like 6' or so. stood on the end, and it would mostly do the job. with my new impact however, i dont even unstake em if the owner or myself has a new one, i just blast em off. puts a smile on my face every time.
BrokenRex is offline   Reply With Quote
Old 04-27-2008, 11:49 PM   #14
HONDA HUMPER
93AccordEX's Avatar
Ride:  A Spaceship!
Rep Power: 12 93AccordEX is a jewel in the rough93AccordEX is a jewel in the rough93AccordEX is a jewel in the rough
myspace
Life can be HELL without a good impact gun
Originally Posted by BrutalB83 View Post
Awww...I thought this thread was going to be about drag queens...
My Projects:
C
ore support on a 96 Nissan Sentra
My CB7 Build (Taking forever to get started)
93AccordEX is offline   Reply With Quote
zc transmisson axle question noserviceinecho HYBRID -> ED-EF / DA 1 12-17-2007 10:50 AM
DIY: How to change an axle Calesta General Tech Articles 1 05-20-2005 09:30 AM
How to change an axle on Civic / Integra Calesta General Tech Articles 0 09-15-2004 08:06 AM
Axle Question slammedcivic HYBRID -> EG-EK / DC 6 07-02-2004 11:34 PM
Which Axle GSRCRXsi General Tech and Maintenance 2 01-31-2003 03:56 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
