Axle size question
Old 09-19-2009, 03:28 PM   #1
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 21 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
Default Axle size question
I got a remanufactured axle from autozone about a month ago, finally got around to doing it. The passenger/transmission side. I took the old one out and it seems to be about an inch longer than the new one. I thought all of the hatchbacks/CRXs were the same except the STD 3dr/CRX HF? The splines on the new axle are the same to the hub. It's a DX with Si transmission. Did they give me one for a sedan?
PSN: Korax37
Korax is offline   Reply With Quote
Old 09-19-2009, 03:41 PM   #2
AHHVTEC's Avatar
sounds like they gave you the wrong one, take in the old one to compare it, they should have a bunch of honda axles in stock
AHHVTEC is online now   Reply With Quote
Old 09-21-2009, 11:51 AM   #3
jlicrx's Avatar
there are only 2 different passenger side axles for the 88-91 Civic/CRX (except for 4wd)
one fits the Civic STD (originally 4-speed) and the CRX HF - it has a collapsed length of 23.75", has 23 splines on the outboard CV joint and 25 splines on the inboard CV joint
the other fits everything else (except 4wd) - it also has a collapsed length of 23.75", has 26 splines on the outboard CV joint and 25 splines on the inboard CV joint
maybe someone put a 92-95 axle in it - it has a collapsed length of 24.50", has 26 splines on the outboard CV joint and 25 splines on the inboard CV joint
ZCspeed Racing
Old 09-24-2009, 06:01 PM   #4
Korax's Avatar
They gave me one for the sedan. It just sucked, already had it out and I had to damage it to do that. There was no putting it back in and taking it back. Tahnks for the info.
PSN: Korax37
Old 09-24-2009, 06:55 PM   #5
jlicrx's Avatar
Civic sedan axles are no different from hatch or CRX axles
ZCspeed Racing
Old 10-16-2009, 04:36 AM   #6
Greenhorn
Rep Power: 0 honda333 is on a distinguished road
Can you please tell me the length of both shaft and halfshaft of civic95 eg6 with b16a?? Thanks
honda333 is offline   Reply With Quote
Old 10-17-2009, 02:23 PM   #7
Korax's Avatar
Make a new thread in the Hybrid EG section. I don't know the answer but someone will and it'll be easier to get your answer there.
PSN: Korax37
axle nut size on d16z6 95EGCoupeVtec Civic and del Sol - EG and EK 5 04-20-2009 04:07 PM
tire size question Skydive2144 Wheels / Suspension / Tires / Brakes 1 10-14-2007 12:20 PM
Tire size question? skivic89 Wheels / Suspension / Tires / Brakes 2 03-12-2007 11:23 PM
What's the size of the nut for my axle? MarkJimenez99 General Tech and Maintenance 7 01-25-2007 04:13 PM
axle Nut size? 90 crx hf ryangt General Tech and Maintenance 5 01-03-2005 12:02 AM
