| | LinkBack | Thread Tools |
| | #7 |
| Junior Member Join Date: Feb 2003 Location: Rockford,IL. Age: 58
iTrader: 0 / 0% Ride: 1990 CRX Si
Rep Power: 15 | I had a bad B16 distributor on swap. We used a D16 Dist with the ear cut off till the B16 dist showed up. Last edited by CRXSIR1; 08-22-2006 at 10:56 PM. |
| | #8 |
| Junior Member Join Date: Jun 2006 Location: Texas
iTrader: 0 / 0% Ride: '91 Z28 '91 CRX SI '03 RAM
Rep Power: 8 | Sorry for jumping on your post, but I have a ismilar problem and didnt want to start a new thread. I was wondering, I bought a 91 CRX Si, it has a B16a swap. The disributor has the ears broken off. So is it a D16 distributor? For a daily driver would I be better off getting a B16 unit? How can I tell if it is obd0 or obd1?? |
| | #9 |
| FüK-VTEC | More than likely if it's a B series VTEC and the ear is broken/cut off, it's an LS distributor. Honestly, if it's working and not throwing any CEL's, I'd leave it alone. If it's OBD0 it'll have two round cream-colored plugs, and if it's OBD1 it'll have two square grey-colored plugs. If the wires are soldered/spliced/cut there's not a whole lot of certainty, but if it has been spliced and there are OBD0 plugs then it's probably an obd1 distributor with obd0 plugs, and if it's got obd1 plugs it's an obd0 distributor with obd1 plugs (with the reasoning being the only reason you'd splice it was to retrofit a distributor to a harness, and if it was an obd1 distributor there'd be no reason to retrofit obd1 plugs onto it)... Honestly, I've never heard of anyone cutting and splicing a D-series distributor onto a B-series motor, although I don't doubt that it's possible. Like I said though, if it's working 100% fine and not throwing any codes, I'd leave it alone unless you plan on doing more upgrades to the motor, that would require OBD1. |
| D16z6 | JBHonda | HYBRID -> EG-EK / DC | 95 | 01-21-2010 09:46 PM |
| d series alt on a b series engine! | civiclxb16 | HYBRID -> EG-EK / DC | 8 | 12-12-2004 08:02 PM |
| ZC, D series, whoopty whoop | UDT | General Tech and Maintenance | 15 | 10-20-2004 09:46 AM |
| K series vs. B series | Frankie P. | Members' Lounge | 10 | 09-16-2003 09:46 AM |
| Can I put a D series tranny on a B block? | Calesta | Swap Articles | 0 | 01-02-2003 04:59 PM |
