| | LinkBack | Thread Tools |
| | #1 |
| Member | I have a ls/vtec like I said I need a tranny but which one I should take. I want close ratio which tranny is the best with close gears! any help will help. it has b18 bottom and b18 vtec head jus in case! |
| | #2 |
| Boosted ls/vtec ohh yeah! Join Date: Jun 2006 Location: Omaha Age: 24
iTrader: 0 / 0% Ride: EM1 EBP boosted ls/vtec, EM1 EBP Daily Driver
Rep Power: 19 | Stick with a vtec transmission either out of a si or gsr or type r. The b16 and type r transmission share the same gearing however the type r transmission has a limited slip from the factory which improves traction greatly. But if you dont want to spend the money get a b16 or gsr tranmssion. Stay away from the integra ls transmission the gears are very long and horrible for all motor setups. Good luck!! |
| | #4 |
Rep Power: 19 | Check out this site it will have the transmission code and even the gear ratios. Make sure you pay attention however to which ones are hydolic and which are cable so you dont get the wrong one. Good luck!! Honda Acura Forum - Tech Performance Forums : Civic, Integra, Accord - B-SERIES TRANSMISSION SPECS AND CODES |
| b18 to a b16 | b18civic1013 | HYBRID -> EG-EK / DC | 4 | 11-01-2007 05:00 PM |
| b18 block/ctr's and b16 J1 tranny | Acrite3404 | Parts: For Sale/Trade/Wanted | 6 | 03-22-2006 01:02 PM |
| 91 CRX HF; B18 or B16, that is the question | twinky_beavis | HYBRID -> ED-EF / DA | 7 | 12-07-2003 10:34 AM |
| b16 or b18 gsr | SiKoNe | HYBRID -> EG-EK / DC | 6 | 12-01-2003 06:44 PM |
| Need Help on B16 or B18 | Sunkist | Engine Building | 1 | 11-11-2003 10:33 AM |
