¿GANGSTA GREMLIN?
Ride: 91 CRX si
yep it should be direct drop in
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
nope, you'll have wiring issues. a b16a2 is obd2b, therefore, your going to need to add some wiring. do you have the ecu it comes with as well? or you can convert the a2 to OBD1 with a1 parts, if they're not damaged or can be used...
but other than wiring it should be fine, unless you choose to go obd2, then you'll need the emissions equipment why you doin this? __________________
YBLEGAL.NET → Profile • Projects • Parts For Sale → Steel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal |
#5 | |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 06-02-2008 01:13 AM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-26-2008 08:53 PM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-11-2008 03:13 AM |
| Jdm Honda B16a2 Dohc Vtec B16a2 92-95 Sir-ii Full Swap | RSS-Bot | Auctions | 0 | 05-03-2008 08:43 PM |
| B16a2 Into 1990 Civic Std. | AlwaysMovin | HYBRID -> EG-EK / DC | 2 | 02-20-2003 05:13 AM |
