b16crx question
Old 08-29-2009, 04:51 PM   #1
Greenhorn
Rep Power: 0 b16crxb16delsol is on a distinguished road
Default b16crx question
i bought a crx and the wirering is pretty hacked. it used to have a vtec controller but for some reason my buddie ripped it out so obviosuly it wouldnt hit vtec. so i reran all the vtec wires, solenoid, pressure switch, o2 sensor, and the knock sensor. but it still wont hit vtec. any ideas? thanks
b16crxb16delsol is offline   Reply With Quote
Old 08-30-2009, 03:02 PM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
any codes being thrown? what ecu are you using?
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 08-30-2009, 03:08 PM   #3
Greenhorn
pr3 ecu. it threw a engine coolant sensor code, tps, and vtec pressure switch. i replaced tps but i think it might b the wiring becaese the previous owner converted from dpfi to mpfi and i dont know anything about that and it looks kind of hacked. but it threw the codes wehn i drove it home. sinse then ive replaced tps sensor and wired vtec and the engine coolant sensor. do the codes dissaprear off the ecu after u fix them?
Old 08-30-2009, 09:40 PM   #4
Greenhorn
ok i fixed all the loose wires and have my ecu code down to just engine coolant temp sensor. and i know i need that for vtec to work. but i cant figure it out. i have the one wire grounded and the other ran to the ecu where it needs to go. but its still throwing the code like its not working. any ideas?
Old 08-30-2009, 11:43 PM   #5
D16SiHatch's Avatar
you need to disconnect the battery for a min or two in order to reset the ecu and remove all codes. if after doing so the ect code still comes back then i guess you can try testing the sensor to see if its bad.
91 Civic Si
Old 08-31-2009, 10:28 PM   #6
Greenhorn
does the engien temp sensor have two hots or a hot and a ground?
Old 10-13-2009, 02:22 PM   #7
Greenhorn
Rep Power: 0 b16a2man is on a distinguished road
this is my problem too. i really would like someone to throw us some answers. i have been working on this swap to long for this to screw me.
b16a2man is offline   Reply With Quote
Old 10-15-2009, 08:45 PM   #8
Greenhorn
bump for help or an answer
motor mount question and gasket question 93integraxchic HYBRID -> ED-EF / DA 2 07-12-2007 01:50 AM
can someone do me a favor? (simple wiring question and speedo question) civiclxb16 ECU's, Electronics, and Tuning 2 03-29-2007 11:21 AM
what should my b16crx run in the 1/4mile? 1320king HYBRID -> ED-EF / DA 6 11-22-2006 06:03 PM
Tax Question JDMPlaya Members' Lounge 12 01-30-2006 12:07 PM
Tired Of Your B16crx? heterosapian HYBRID -> EG-EK / DC 1 02-20-2003 03:50 PM
