Greenhorn
Ride: 88 ef..b18a1..
i just bought a ls swap...i have a 88 ef...has anyone done this swap before? how hard was it...and has anyone got this car reffed with this motor....NEED INFO!!!
My name is Byron.
Ride: 89' DX Hatch w/B16
Its a pretty basic swap depending on the trim level of your car, search a little and you will find a ton of info on this swap.
^ (dont listen) Dont PM me with tech questions. I will not answer them. There is a hidden message here. "Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details." "In the dice game of life who gets the last roll?" |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
word.pretty easy,1 step up from direct replacement.you will need
mounts(i have a set for sale if interested) axles ecu shiftlinkage fluids and the accessories for the motor __________________
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
Greenhorn
i bought the full swap for $750 off a friend...b18a1..AVID mounts..b16 tranny re-geared to have 4,5th ls gear..lightened flywheel..shift linkage with short shifter................how hard is the swap? does it drop right in?
#5 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
wow you got a hell of a deal..it doesnt exactly drop right in..you have to dent the drivers frame rail to clear the alt. and i had to cut the front mount bracket off the front crossmember,you also have to dent the lip down on the rear crossmember to clear the tranny bracket
#6 | |
Frommy understanding the only changes really you have to do with teh wiring is at the dizy.
| 88 hf to b18a1 | kricket3000 | HYBRID -> ED-EF / DA | 16 | 03-29-2008 01:46 PM |
| DSM 14b on B18A1 | DOHCtaDA9 | Forced Induction | 6 | 03-16-2008 05:16 PM |
| Obd0 B18a1-odb1 B18a1 | brian11to1 | HYBRID -> ED-EF / DA | 29 | 05-14-2003 08:26 PM |
| 90' B18a1 Swapped In A 93' B18a1 | brian11to1 | ECU's, Electronics, and Tuning | 4 | 05-08-2003 10:49 AM |
| Turbo A V-tec B18a1 Or B18a1 | YangpaNemsay | Engine Building | 1 | 02-23-2003 10:21 PM |
