I just picked up a b18a1 motor and i have no clue what i need to get to do the swap. the motor was in a 91 acure integra. can anyone tell me everyhting i will need to do the swap? will my wiring harness work? ecu? motor mounts? anyhting else? OH its goin in a 90 civic 4 dr
thanks |
#2 | |
universal logic protocol
Ride: 99 VW GTI 07 Jeep Compass
If I were you get a Haynes or Chiltons manual for both the Civic and the Integra so you can compare ecu wires. You are going to need to switch from DPFI to MPFI. As far as parts I assume you have the Engine, Transmission and ECU. You should also get the engine wiring harness for the Integra if you don't have it already. I would start on the wiring part first as it will take some time. I'm doing the same thing only I just decided to rewire the Civic like the Integra. If you want some pics check out my thread
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now 07 Jeep Compass If you ever find anything I write usefull please leave rep. Rebuilding a Transmission http://www.the-whiterabbit.com |
#3 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
#4 | |
Author of the Madness Man
Ride: 1973 Datsun 240z
b18a1 swap « Project CRX Without knowing exactly what model civic you have, it's hard to say what you'll need. Is it DPFI or MPFI? it'd be appreciated if you subscribed to my projectcrx site as well. __________________
Do NOT PM me with tech questions! Instead, come see my Automotive Addicts Anonymous page for tips and advice! |
#6 |
You shouldn't need to swap the hub assembly for any reason. Just remove the inner dust shield, and the Integra axles (which are sensitive to ABS or not ABS) should slide right in and not mess with geometry at all. Go for '90 - '93 Integra axles.
#7 | |
Ride: 91 si hb gsr swap
#8 |
It may be different on a per-trim level. My CRX Si had no problems whatsoever with 90-93 LS/RS axles.
#13 |
The YS1 is exactly the same transmission I used for my CRX. It's the default B18a1 cable tranny. I don't see any reason you should need to swap your knuckle assembly for that.
Even when I DID swap my knuckle assembly (including wheel hubs) for the '91 Integra knuckles(for a brake upgrade), the very same axles worked perfectly. No troubles whatsoever. __________________
#14 |
![]() well whatever, the fact is, when I did my swap I had to use the hubs off the tegge, because the splines on the tegge axles were bigger!Last edited by xips(86CRXSI); 01-15-2008 at 11:35 PM. |
#16 |
the 4speed civics all came with smaller hubs, and will need to swap them to the ex, si or integra hubs. that includes all years of the HF rex, hatch std and one of the civic sedans (i dont remember the year/model). if your swap recipient is a 4 speed, you'll need the hubs, if it's got five forward gears, you're fine with yours.
| b18a1 swap | celicaboy1984 | Civic and CRX - EF | 4 | 01-13-2008 01:21 PM |
| B18a1 Swap | integrawide90 | Integra | 0 | 10-01-2007 02:42 PM |
| B18A1 swap | 98wtcivic | Civic - EP, FA, FG | 3 | 10-01-2007 11:39 AM |
| need help with b18a1 swap | CrixSi91 | HYBRID -> ED-EF / DA | 15 | 04-13-2007 07:35 AM |
| b18a1 swap in 92 civic hatch. | brush | ECU's, Electronics, and Tuning | 2 | 11-02-2006 05:33 PM |
