B18b1 swap
Old 08-05-2009, 03:12 PM   #1
Greenhorn
Rep Power: 0 kaobigdog is on a distinguished road
Default B18b1 swap
What work would have to be done to put a B18B1 ls motor into a stock 91 civic Hatchback with a standard transmission.
kaobigdog is offline   Reply With Quote
Old 08-05-2009, 03:58 PM   #2
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
search man..........this has been done lots of timesa.
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 08-05-2009, 05:48 PM   #3
LOWLIFE's Avatar
Ride:  91 Civic Hatchy
Rep Power: 1 LOWLIFE is on a distinguished road
Send a message via AIM to LOWLIFE Send a message via Yahoo to LOWLIFE myspace
i guess ill bite even tho i still say search as well....
new transmission, shift linkage, engine, ecu, mounts, a BFH to dent clearance for alt, use a civic rear engine mount (the metal bracket thingy, not sure the year) instead of the teg one if you dont wanna notch rear crossmember, then depending if you have MPFI or DPFI you may or may not have to do the wiring conversion, im sure a couple of little odds and ends things im forgetting but you get the idea.
91 hatchy with an engine that makes it move along and a GSR tranny (Only good thing that car ever had).
Currently awaiting surgery on the head after some misfortune
Thants not N2O... Thats my Air Conditioning... For the engine...
LOWLIFE is offline   Reply With Quote
Old 08-06-2009, 12:16 AM   #4
Greenhorn
so I am thinking it is more work than it is worth.
Old 08-06-2009, 12:43 AM   #5
LOWLIFE's Avatar
depends how you look at it.
I freaking love mine, ill give you a 50 shot of spray on your car now and still walk you.
Old 08-06-2009, 12:51 AM   #6
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
depends what you want out of the car and what you're willing to spend. if your just trying to get a car running then stick with d-series. if you want more power and more modding potential then go with a b. in doing so though you must change numerous things. motor mounts, shift linkage, ecu, axles, throttle cable, etc.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 08-06-2009, 10:57 PM   #7
89y49rexsi's Avatar
Ride:  89 civic sedan
Rep Power: 2 89y49rexsi is on a distinguished road
i actually use my stock throttle cable on my b16a and it works just greatbut i would recomend if your going to spend all the money anyway then you should get a b16 or a gsr the ls is not a very big bump in power from a stock motor its not even a 50 hp bump so i would go with a b16, gsr, or an itrgood luck
89y49rexsi is offline   Reply With Quote
Old 08-07-2009, 02:10 PM   #8
D16SiHatch's Avatar
b16a - 160hp, 111tq
b18a - 142hp, 127tq
what the ls lacks in hp, it makes up for in tq. plus you have to rap the shit out of a b16 to get anything out of it. just depends where you want your power to be.
91 Civic Si
b18b1 swap help Hondaandacura078 HYBRID -> ED-EF / DA 5 08-07-2007 09:38 AM
89 CRX B18B1 Swap crxprodject Civic and CRX - EF 3 05-16-2007 12:46 AM
b18b1 swap, short block, trans, head, swap parts, jacksonracing supercharger egriffith45 Parts: For Sale/Trade/Wanted 4 01-21-2007 11:06 AM
b18b1 swap 97 turbo coupe HYBRID -> EG-EK / DC 2 10-19-2003 03:25 AM
b18b1 swap 97 turbo coupe HYBRID -> EG-EK / DC 2 10-18-2003 01:01 AM
