#2 | ||
Honda Enthusiast
Ride: '94 EG sedan w /Z6, '97 EK hatch
My friend, just a piece of advice...please only make one post for your topic as everyone WILL see that specific post and WILL reply to it, should you have provided enough information to go on. Also, you can always edit your post to add more information at anytime, instead of making FOUR different posts. That, I would think, would be a good way to get your thread locked.
With that said, have you done any research on motor mounts? I would suggest using the search feature and checking out other posts relating to your question. Also, Google will help you out a lot. You never specified what year the Civic hatchback is, by the way. I wish you the best and since you seem to be new here, welcome to HS. ![]()
Max? There is no max. Max just means you gave up. This is my thread: http://hondaswap.com/engine-building...g-wind-110848/ My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406 Quote:
żUnKnOwN?
Ride: 91 CRX si
what year civic is it going into?if its the same generation as the crx..then you would use all of the stuff you have now..and just put a dent on the drivers framerail right under the shock tower,and bend the lip down on the rear crossmember
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX R.I.P BEN LEE2/24/08 we love and miss you R.I.P Rex 8/18/08 coolest dog ever!!! GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#5 |
you get the BRAKE
I think he means eg. If that is the case, he will need a lot more than just mounts. hydraulic transaxle, obd1 ecu, mounts, shift linkage, axles. OBD1 distributor/injector clips.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#6 | |||
The Kicker of Elves.
I'll go out on a limb and assume you're talking about another EF since you posted this in the EF forum. The CRX and Civic hatch the same platform so nothing changes.
I don't think I'd want something that I'd have a hard time fitting.
Don't misinterpret what I say. Quote:
#7 |
Got V-tec?
yeah I would recommend using Arizona Race mounts or Hasport cause others are just metal and will cause engine sag and engine vibration due to welds on the mounts. Billit is definately the way to go. Only buy once and don't have to worry about breaking mounts.
| b20 noobie question | monkk | Civic and CRX - EF | 0 | 03-08-2008 01:45 AM |
| noobie question | khmerb0ix7o2 | Forced Induction | 2 | 01-19-2004 01:10 AM |
| Stupid Noobie Question | crombie09 | HYBRID -> ED-EF / DA | 31 | 01-12-2004 02:20 PM |
| Noobie Turbo Question | b18c1civic97 | Forced Induction | 9 | 01-07-2004 12:22 AM |
| noobie question | mikoling | General Tech and Maintenance | 10 | 08-19-2003 01:42 AM |
