ok.. i was driving my honda (89 dx w/e SOHC ZC) and i heard it backfire from the IM. i know it kinda boggs a bit from 1/2 to full throttle, but this time it backfired!
im running a PM6 ECU.. idk whats wrong.. im going to check my timing tomorrow.. all my fuel system is stock.. AHH! help! |
backfiring thru intake manifold usually caused by ignition timing too far advanced, camshaft timing not right or intake valve not seating properly (could be bent) - could also be spark plug wires not in correct order
ZCspeed Racing |
the only way im assuming it was from the IM is because the sound came from the front of the car. it was a distinct backfire sound (the 'pop' sound)
i'm going to try to check my timing ASAP, thanks jlicrx |
#6 |
did that end up fixing it for you? the firing order?
i'm going to pull the honda into the garage when i get a chance and check all that. but im almost positive my firing order is correct 1342 i believe is how its plugged |
#7 |
Ride: 88 Honda Civic HB
make sure its going the right way. I did 1342, but did it the wrong way(ended up being 1243), and had that exact intake poping noise. I know for sure it was intake too, because the intake pipe was pointed right towards me.
#9 |
#11 |
Ok i got a 91 civic dohc ZC and im having the same problem. I checked timing and the firing order didnt change for no reason. If you could give me some more options of things to check that would be great.
| Bad stutter and backfire | silva95teg | HYBRID -> EG-EK / DC | 15 | 06-19-2006 08:06 PM |
| HUGE backfire while car not on | formby | General Tech and Maintenance | 7 | 03-31-2006 11:46 PM |
| Pontiac Backfire... er Sunfire for sale | 5speed4life | Vehicles: For Sale/Trade/Wanted | 3 | 06-12-2005 11:14 PM |
| Intake Backfire please HELP! | takinbackchristo | General Tech and Maintenance | 0 | 09-19-2003 04:10 PM |
