best ecu for zc swap
Old 03-22-2008, 06:43 PM   #1
goose2's Avatar
Rep Power: 5 goose2 is on a distinguished road
Default best ecu for zc swap
what is the best ecu for a zc sohc swap in a crx?pr4,pm6,pm7?
team loud & clear
2007 stock 0-600 world champion usaci
0-600 stock world record holder usaci
goose2 is offline   Reply With Quote
Old 03-23-2008, 02:22 AM   #2
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 5 monotech909 is on a distinguished road
Thumbs up
Pg7 or Pm7 ---> Pg7 rev limiter is set @ 7,500 Rpms stock I have a few available if needed
monotech909 is offline   Reply With Quote
Old 03-23-2008, 05:29 PM   #3
goose2's Avatar
so the PG7 : 86-89 Integra (86-87 vac advance, 88-89 electronic advance) will work in a 91?wouldn't the PR4 : 90-91 Integra LS/GS be just as good?
team loud & clear
Old 03-23-2008, 06:42 PM   #4
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Isn't the one that comes stock with the motor always the best choice? Why would you use a 90-91 Integra ECU? That's a completely different motor...
PSN Network ID: BrutalB83
Old 03-23-2008, 07:06 PM   #5
goose2's Avatar
more power.besides the pm6 and pm7 are impossible to find in automatic. i was told that the pr4 ecu would work for my application.was i told wrong?
team loud & clear
Old 03-23-2008, 07:15 PM   #6
Brutal Moderator
BrutalB83's Avatar
myspace
I understand you want more power, but just haphazardly sticking in a computer from a completely different engine isn't necessarily going to get you that power. A different ECU might raise the rev limiter or inject more fuel at certain points, but if the motor wasn't built to handle it, then what's the point? You'll just be fucking up your engine...kind of like installing one of those crappy E-Bay "performance" chips...
Old 03-23-2008, 07:24 PM   #7
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 221 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Why do people think a different ECU will make more power.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 03-23-2008, 08:23 PM   #8
Brutal Moderator
BrutalB83's Avatar
myspace
Probably because they know someone or have heard of someone using a P28 or P72 or whatever for their built motor, and then assume that throwing a different ECU in there will automatically give you a power boost...
Old 03-24-2008, 03:32 AM   #9
Got V-tec?
Ride:  Whip!
Cool
Definately not true who ever said that must be a rookie.
Pr4 will run rich it will work but will cause you to run richer not a good choice unless thats your only source.
I would rather go with Pg7 or even a Pm6 but Pg7 for being stock is well worth it.
If you get a Pm6 make sure its a 28 pin that way you can program it later if needed. Make it worth it if you happen to get a Pm6
Old 03-28-2008, 10:55 PM   #10
Rep Power: 5 maykelcj is on a distinguished road
hands down the best ECU I found for my ZC was a chiped pm6 with modified PM7 maps. I got it from a guy that chips them on theZCR.com. Don't get fooled the best ECU is the one made for your engine! I tied the PM8, PG7, and the PM7 maps make the car run like it suppose to run.
you don't need higher rev limit on the ZC because ~6700 rmp it is done making power.
here is a link to that guy. He is really nice and easy to deal with. www.thezcr.com - Auto Electronics
if you decide to go for the PG7 I have an automatic one that I used for my ZC at first.
maykelcj is offline   Reply With Quote
Old 03-30-2008, 01:27 PM   #11
Got V-tec?
Ride:  Whip!
Ericks racing can chip pm6 ecu and pr4 for your application.
Hes done a few of my Pr4 ecus to work with my Ls/V-tec builds and does a hell of a job. Price is definately worth it.
ERE OBD 0 PRograms
Head swap brownkobe8 HYBRID -> BA-BB /CA-CD 5 03-08-2007 10:59 PM
Need help deciding which swap, B18A or H23A bigblockhatch Civic and del Sol - EG and EK 8 11-20-2006 03:37 PM
need some info on swap gin Civic and del Sol - EG and EK 0 09-16-2006 09:22 PM
need info on b18 swap gin Civic - EP, FA, FG 1 09-13-2006 09:15 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
