#1 | |
I need some ligaments!!!
Location: laurel, montucky (ten minutes out of billings)
Ride: 89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
i was wondering what engine i have in my rex... it's an 89 hf with multi port injection but no vtec. that and does anyone know the safest level to take the rev limiter to? limits at 5500. thanks.
car + vinyl = big hp!!! ![]() wipe your mouth, there's still a tiny bit of bullshit around your lips Quote:
( 0.o ) ( > < ) The bunny will rule teh world! Bwahahahaha!!!! |
Ride: 95 Civic
this site should tell you what you need to know
Honda Engine Specifications. |
HS Troll...And Mod
Ride: 2001 Honda S2000
howd you get a 89 with mpfi...thats odd. those are usually dpfi.
Do you have a tac in your car? If so, consider the red area the redline. I dont think the change between mpfi and dpfi is going to warrant a higher redline. Check the engine code on the block and get back to us. Someone might have swapped a different engine in there. Itll look like this: ![]() your engine will look SIMILAR to this one, and it will be under the upper radiator hose. ![]() __________________
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
Führer Mod
the 90-91 HFs are mpfi.. the 88-89 are dual points
#5 |
HS Troll...And Mod
![]() thanks bro, thats what i was getting at __________________
#6 |
HS Troll...And Mod
Thats probably chiltons talking. those are the same people that told me my exhaust manifold should be tightened to 44ft/lbs.
hf definitely doesnt have the same engine as the si. __________________
#7 |
HS Troll...And Mod
*forgiven.
#8 | |
i'll have to go look at it tonight cause i'm at school. but the title says 89 crx and in the back tail window it says HF in big white letters. i know i have the hf trans cause of the drop in rpm between gears. i'm just as confused as y'all are...anyway i will post the numbers up later.
#10 | |
| cx with d16z6 engine rev problems | crxsi | HYBRID -> EG-EK / DC | 1 | 09-28-2006 12:06 PM |
| Boost & HP Level | Turbo&Auto | Forced Induction | 56 | 09-13-2006 01:18 AM |
| Engine died, can't figure out what's wrong! | $k@m Art1$t | General Tech and Maintenance | 12 | 07-31-2004 04:34 PM |
| ecotec | tweakman | Members' Lounge | 22 | 09-29-2003 03:23 AM |
| What is double clutching? | Calesta | General Tech Articles | 0 | 12-27-2002 03:06 PM |
