ok so i bought a new intake for my 91 crx dx right. but i went out to install it. i try to pull out the o2 hose from the vale cover then there a two more hose that are connected to it. one i think goes to the thottle body and the other to the intank maniflod. i pulled the hose form the intank off and aintfreeze came out. so i put it back. the thing is that am not sure if i can cut the hoses from the o2 off the the other ones that are going into the intank and body. is the antifeezer getting sucksion from the o2 tube? i need to put the aftermarket tube form the intake on or it wont fit. i know enough about cars to do this but done want to cut some a fuck things up.
so if any one out there has done this before on a 91 crx dx please help me out. thanks for any help. oh and sorry for the bas typing. ![]() |
I made the millionth post
Ride: 03 350z, 03 CL-S, 02 Excursion, 91 CRX Si, 86 CRX Si
no, theres no suction from the vent tube.
it sucks because EF's have the 2 tubes "welded" together with the metal clip in the middle. What I always did with my EF's was just cut the vent tube on either side of the metal tab and then just try to hide that coolant tube down underneath the intake or remove both and just use a rubber hose for the coolant line. Use the vent tube that came with your new intake and, you're talking about this right?
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE. |
yea thats what am talking about. so its safe to go ahead a cut that little black clip on the hoses off? i just thought that thats were the coolent gets its suction from to continue the flow.so those hoses dont have anything to do with each other and the coolent will continue to flow correctly?
and the pic is a great piture of what i was talking about. thanks. |
#5 |
its not a clip...they're welded together
it sucks, but they're all like that and yes, the two have nothing to do with each other
#7 |
Savage Reins Supreme
Ride: 88 Civic Hatch,93 Civic Coupe
hey lookout take that two hose metal thing off and grind away the top tube for the air intake with a wire wheel/grinder thats what I did and it worked great but dont grind too much off
#8 |
Ride: 06 gmc 2500 Turbo Ls Civic
my old intake came with a tube for each. aem with the hook up
Boost Big or Boost Small. Just make sure you remember the Boost. |
#9 |
so ur car came with two seperate metal tubes or the two stuck together with the weld if its the welded u can get rid of the top tube for a cleaner look by grinding it off like I said thats what I did and I got alot of "hey man that looks clean"
Savage Dreams |
#10 |
Admin with a big stick
Ride: 2003 S2000
I cut mine off with a saw, then cleaned it up with some wrap on top. Easy.
#11 | |
lol what ever floats ur boat right if it works and looks good then who can complain right and if they do hey its not thier car is it????I was gonna use one of my cutters but I was paranoid I would slip and cut too much or something so I grinded it since it takes less off at a time.well hey man good luck with your car!!!!!!!!!
Savage Dreams |
#12 | |||
The Kicker of Elves.
I did something really easy. I got enough hose to completely remove that bastardly thing. Problem solved.
Don't misinterpret what I say. Quote:
#13 | |
VTEC CRX
Ride: 1990 Honda Civic Hatchback Std.
ED6 - 1990 Honda Civic Hatchback Std. Swapping in soon: JDM D15B VTEC, Chipped P28, Teg ZXi Tranny w/ HF 5th & OBX LSD R.I.P. 11/2/2006->> 1989 Honda CRX HF - 253K |
