car will not start
Old 06-17-2008, 03:12 PM   #1
Ride:  89 honda crx si and 94 chevy s10 dropped
Rep Power: 6 sevenhillsbilly will become famous soon enough
Exclamation car will not start
well i have aproblem my car is stranded at work and wont start
i have checked the fuel pump and fuses and relay and still wotn start can any one help me i need to know what to check to make sure it will start because it is getting fuel and spart but wont start
sevenhillsbilly is offline   Reply With Quote
Old 06-17-2008, 08:36 PM   #2
dsix
hondadsix's Avatar
Ride:  1990 crx dx jdm b16 swap ls tranny future turbo
Rep Power: 0 hondadsix is on a distinguished road
Default that sucks
Try the spark first. see how strong it is. pull a wire out of the distributor and let the electricity ark to the wire. if the spark is real dull it is the coil. what did it do when you shut it off does anyone have acess to the car who could have swapped the wires around as a joke mayby. if not one of these things idk b/c if you have spark, fuel, and ignition timing you should have fire. also check the plugs for fouling.
hondadsix is offline   Reply With Quote
Old 06-17-2008, 09:37 PM   #3
no no one messed with the car i parked it when i got to work and i went to go turn it on to show someone my exhaust but it wouldnt start and it was running funny on the way to work so i was gunna do plugs anyway so maybe it might just be that
Old 06-18-2008, 02:59 PM   #4
dsix
hondadsix's Avatar
maby, if not try the fuel filter it may be clogged so you can hear it prime but no fuel to the injectors. it is probably something minor.
Old 06-20-2008, 08:06 AM   #5
Rep Power: 0 crsexy is on a distinguished road
Sounds like your coil it bad, pull your dist. cap off and look at the coil plug, it's probably very corroded and brittle.
crsexy is offline   Reply With Quote
Forum Jump
Won't start,,,,,,,,,sometimes :( alexfleury Civic and CRX - EF 10 10-18-2007 07:53 AM
Car won't start! I've tried everything! La_Pieuvre General Tech and Maintenance 4 01-04-2007 01:11 PM
CRX won't start CrXRacr General Tech and Maintenance 3 11-19-2003 01:42 PM
could i still start my car.... Vtec Andy..... Engine Building 4 11-08-2003 03:42 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
