check engine light
Old 10-18-2006, 07:18 PM   #1
Ride:  90 civic lx w/b18a1 swap(daily driver),91 crx si w/c5 in it(on a 100shot).01 s2000 for the weekends
Rep Power: 10 redef91 is off the scale
myspace
Default check engine light
whats up guys i got a 97 type r motor in my 91 crx...when i get on it vtec works good then sumtimes then check engine light comes on n vtec dont work.....i did the test shit n the light blinks twice slow twice fast....sumone told me its a vtec switch.....i kno it aint to wiring since vtec works most of time....is it the solienod or the senor on the vtec thing...help guysss.....
redef91 is offline   Reply With Quote
Old 10-18-2006, 07:30 PM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
code 22 vtec pressure switch
AHHVTEC is online now   Reply With Quote
Old 10-18-2006, 10:34 PM   #3
myspace
what is it thou the soleniod or that other sensor......thanx
Old 10-18-2006, 10:39 PM   #4
HS TECH
AHHVTEC's Avatar
its the vtec pressure switch it screw into the side of the selonoid. it should be green in color
Old 10-19-2006, 11:24 AM   #5
myspace
damn how does that shit fuck up thou....
Old 10-19-2006, 11:32 AM   #6
HS TECH
AHHVTEC's Avatar
well most of the time a pressure switch wont mess up but it can, so lets hope its the switch.but if its not the switch its either the ecu- wireing -or not enough oil pressure for the pressure switch to read so you oil pump is getting weak..check the screen in the selnoid also to see if its clean
Old 10-20-2006, 01:47 AM   #7
Rep Power: 0 <CRX> is off the scale
hey if its a jdm type r you wont have a vtec oil pressure switch so if your using a usdm ecu then its going to be looking for a pressure reading you can bypass that pressure plug to your selinoid its self to ge a reading and trick the ecu thats if your running the usdm ecu on a jdm motor
<CRX> is offline   Reply With Quote
Forum Jump
check engine light on workerbee General Tech and Maintenance 5 11-29-2005 09:25 PM
check engine light on workerbee General Tech and Maintenance 1 11-16-2005 10:45 AM
Check engine light acting wierd? leonc ECU's, Electronics, and Tuning 3 06-21-2005 04:10 PM
98 civic o2 sensor / check engine light malone68 NorthEast 1 07-12-2004 07:40 PM
check ENGINE light HellBentHONDA ECU's, Electronics, and Tuning 4 05-04-2004 11:21 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
