Codes 10 and 14
Old 06-10-2009, 07:34 PM   #1
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
Default Codes 10 and 14
Since i changed my engine i have had cel codes 10 and 14. I changed both censors and tried different ecu's and engine harnesses with no luck.
any ideas?
Codes:
10 - IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
14 -
IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 06-11-2009, 10:01 AM   #2
jlicrx's Avatar
check your connectors - sounds like you have the two connectors switched
Intake Air Temp sensor (code 10) is a 2-wire connector with red/yellow and green/white wires
Electronic Air Control Valve (code 14) is also a 2-wire connector with blue/yellow and black/yellow wires
if the car was originally DPFI, the EACV connector is green in color
ZCspeed Racing
Old 06-11-2009, 11:23 AM   #3
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 72 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
Yep. ^^^^^ also you might have the connectors switched on the iat and one to the brake system. They are close to each other, this happened to me.
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 06-11-2009, 12:02 PM   #4
jlicrx's Avatar
if the car was DPFI, there is another 2-wire connector in the same area which was for the Tandem Control Valve - it should not be connected to anything, if the car was converted to MPFI - the Tandem Control Valve connector has orange and black/yellow wires
ZCspeed Racing
Old 06-12-2009, 11:14 PM   #5
B ( . )( . )B's
Its still dpfi. Im gonna try switching plugs around tomorrow. keep the ideas coming.
Old 06-14-2009, 11:35 AM   #6
Greenhorn
Rep Power: 0 luggss is on a distinguished road
I all so have the same problem but im gettin a code 20 as well. What is the reason for a code 20?
luggss is offline   Reply With Quote
Old 06-17-2009, 12:32 AM   #7
B ( . )( . )B's
Issue resolved!
I switched the engine harness with my parts car and its fine now.
Thanks everyone!
Needed 93 Acoord Check Engine Light Codes (CEL Codes) 93AccordEX Accord 6 10-15-2007 02:03 AM
ecu codes #1, #2, #22. little help please. zellis Integra 4 01-16-2007 01:14 PM
CEL codes formby ECU's, Electronics, and Tuning 0 02-18-2005 12:37 PM
ECU Codes thebugcha HYBRID -> ED-EF / DA 1 12-31-2003 05:35 PM
ECU Codes Jazzy19 ECU's, Electronics, and Tuning 2 12-15-2003 02:09 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
