crankshaft sensor wiring
Old 08-16-2009, 01:46 PM   #1
Ride:  90 crx with ls swap
Rep Power: 3 spacemanspiff is on a distinguished road
Send a message via AIM to spacemanspiff
Default crankshaft sensor wiring
i had a b18a1 in my crx i spun a bearing and trashed the motor. now im putting a b18b1into it. my problem is that on the a1 the crank sensor is integrated into the distributer but on the b1 it has a seperate sensor. how can i wire it in or can i use my old distributer from the a1
spacemanspiff is offline   Reply With Quote
Old 08-16-2009, 01:55 PM   #2
jlicrx's Avatar
on the B18B1 the sensor behind the crank pulley is not the crank position sensor (CKP) - the CKP sensor for the B18B1 is still in the distributor - the sensor behind the crank pulley is the crankshaft speed fluctuation sensor (CKF) and is not needed unless you are using the OBD2 ECU
ZCspeed Racing
Old 08-16-2009, 02:09 PM   #3
oh ok i was looking at the diagram for that and i saw that i wasn't sure if i needed it or no.
Old 08-16-2009, 08:46 PM   #4
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
nope, don't need it. just use all the stuff off the a1 and swap it onto the b1. only thing left to do is extend the wires for the fan switch from the back of the block over to the side of the head at the thermostat housing.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
crankshaft fluctuation sensor aznhottiekj General Tech and Maintenance 4 08-19-2009 01:47 AM
crankshaft position sensor eric p HYBRID -> EG-EK / DC 1 02-26-2009 08:35 PM
crankshaft speed fluctuation sensor floridachill71 HYBRID -> EG-EK / DC 9 04-20-2007 08:56 AM
CKF Sensor (Crankshaft Speed Fluctuation) ? sal_blkej2 HYBRID -> EG-EK / DC 3 03-05-2004 01:13 PM
Crankshaft Position Sensor unsivil_audio HYBRID -> EG-EK / DC 0 08-18-2003 12:43 PM
