i was wondering how i should go about upgrading my brake system on my crx to the dual piston legend brakes. I was wondering what i would need to put on cuz i thot i figured i would have to just get the whole knuckle assembly, but i jus wanted to get information before i did anything.. help me out thnx
#2 | |
Savage Reins Supreme
Ride: 88 Civic Hatch,93 Civic Coupe
just do the ex front hubs and integra rears its easier and bolt on 90-93 Integra Rear Trailing Arms (with everything attached Rotor, Caliper, E-brake Cables...) or 90-91 CRX Rear Trailing Arms (with same...) You can use either trailing arm but for CRX you need CRX e-brake cables and for Civic you need Integra e-brake cables (might as well get whole CRX trailing arm + cables for CRX, and whole Integra trailing arm + cables for Civic) 90-93 Integra "4040" Brake Proportioning Valve (Prop Valve), HIGHLY RECOMMENDED!!! New Rotors or resurface old ones (I used new Brembo Blanks) Remain. Calipers (if your old ones are in bad condition) Stainless Steel Braided Brake Lines (recommended... I used Good ridges) New Brake Fluid (I used Castrol GTLMA DOT4) Brake Pads (I use OEM Honda/Nissin pads) |
| Big Brake upgrade | jimboburgess | Wheels / Suspension / Tires / Brakes | 8 | 05-16-2006 01:43 PM |
| Brake System Upgrade | QMaze | HYBRID -> ED-EF / DA | 10 | 03-03-2006 06:05 PM |
| Accord Brake Upgrade | reckedracing | Wheels / Suspension / Tires / Brakes | 11 | 06-10-2005 01:42 PM |
| Tired of searching...GSR brake upgrade on EG | hybrid89 | Wheels / Suspension / Tires / Brakes | 8 | 11-27-2004 04:52 AM |
| Brake Upgrade Question | NoJokE | Wheels / Suspension / Tires / Brakes | 8 | 04-25-2004 05:07 AM |
