#27 |
you get the BRAKE
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#28 |
..is grounded.
Ride: '84 buick (rusted)
it means that i've replaced 2 ignition modules for the result of crx win and awesome
marco.... |
#29 |
you get the BRAKE
As Borat would say it..."very niiiiiccceeeee".
#30 |
Is Girl Aggressive
Replaced it twice, once just to kinda go over the spark plugs, spark plugs wires, etc. Second when my distributor crapped out last time, I replaced it again lol. I don't think it's that. I've replaced all parts of the dizzy and most electrical things up top.
I seriously think water/condensation just got in. |
#31 |
Bored
Ride: 91 Civic Si(R)
check your ground wires.
one may be loose and making cintact when you start changing shit out and making the car work, then when you hit a bump just the right way makes it loose contact again. check all grounds and power wires. your haynes manual should have the location for these i believe?
Sociopaths and Sadists make the best business men. |
#32 |
Have you looked inside the cap???
I was driving and my rotor desided to come off, causing the car to die. it was a real cheap fix. The screw to the rotor likes to wallow out. I also have no splash sheilds and i have no problem with water, even when its raining, i sit about 4" of the ground. If you are getting spark out of the wires the dizzy is fine. The easiest way to check the fuel pump is to take the gas cap off and have someone turn the key on and see if you can hear the pump run through the neck.
"RICER"
#33 |
żUnKnOwN?
Ride: 91 CRX si
any updates??
http://hondaswap.com/auto-multi-medi...st1144603.html <my CRX R.I.P BEN LEE2/24/08 we love and miss you R.I.P Rex 8/18/08 coolest dog ever!!! GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#34 |
Is Girl Aggressive
Yeah, it was the dizzy. I told everyone I thought it was, then I went into the mechanics. They said they think it might the alternator, but they'd have to check. Got everything switched out, new dizzy and silicone (they couldn't get a seal) between the cap and dizzy for no charge. Thanks god for lifetime warranties.
#36 |
żUnKnOwN?
Ride: 91 CRX si
did you put some rtv around where the cap and metal meet?
| DIY Broken Head Bolt Removal | Speed Box | Civic and CRX - EF | 6 | 07-16-2007 05:56 AM |
| broken ipod.... broken neck | pissedoffsol | Members' Lounge | 16 | 05-10-2007 05:30 PM |
| Broken block? | crxpower | General Tech and Maintenance | 6 | 03-21-2007 12:26 PM |
| broken trannies | TommYnY | General Tech and Maintenance | 7 | 11-20-2006 05:22 PM |
| broken intake sensor | sappenheimer | Civic and del Sol - EG and EK | 8 | 07-27-2006 02:15 AM |
