crx main relay issues
Old 02-14-2009, 12:59 PM   #1
pappaj's Avatar
Ride:  89 CRX SI (LS)
Rep Power: 5 pappaj is on a distinguished road
Default crx main relay issues
Does anybody have and idea where the #8 terminal is grounded for the main relay. It seems I have a bad ground, when I connect this directly to ground the car will run. Also while running when i give the throttle a quick punch it wants to die. I would love to know where that side of the relay is grounded, everything else works fine it is just the fuel side of the relay.
Please any ideas appreciated
pappaj is offline   Reply With Quote
Old 02-14-2009, 02:32 PM   #2
jlicrx's Avatar
the black ground wire from the Main Relay goes into the harness and connects with the black ECU ground wires from pins A2 and A4 along with a ground wire from some of the sensors and shields and they all end up coming out of the engine harness to a small ring connector that bolts to the thermostat housing:
ZCspeed Racing
Old 02-15-2009, 03:38 PM   #3
pappaj's Avatar
Thanks alot that is awesome. When the main relay chatters the led on the ecu flickers so I kind of figured they had a common ground. Thanks again
Old 02-17-2009, 06:48 PM   #4
pappaj's Avatar
Thanks again that was the exact problem as soon as I went to crack the bolt loose, it was not tight. Something I forgot to tighten when flushing the coolant after the swap. Connection was cleaned up and it runs mint. Thanks
Old 02-19-2009, 11:54 PM   #5
d16a6/d16y8 "mini-me"
89' Project Civic's Avatar
Ride:  1990 Honda Civic Si
Rep Power: 22 89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light
Send a message via MSN to 89' Project Civic
One little ground will do it, man. I am worried about putting my dash back in, incase I miss a ground, hehe.
89' Project Civic is offline   Reply With Quote
Strange problem between main relay, main relay harness, and ECU aasarsak Civic and CRX - EF 5 01-29-2009 05:25 AM
Strange problem between main relay, main relay harness, and ECU aasarsak Civic and CRX - EF 0 11-29-2008 11:58 PM
Main Relay gold-h22a Prelude 0 09-06-2007 09:15 AM
CRX Main relay issues? Z6CRX HYBRID -> ED-EF / DA 8 05-03-2006 03:26 PM
CRX MAIN RELAY AND FUEL RELAY CReX123 HYBRID -> ED-EF / DA 4 07-30-2004 03:04 PM
