CRX motor Swap need Help!
Old 05-14-2008, 06:53 AM   #1
Ride:  90' Honda CRX DX and 04' GMC Envoy SLT
Rep Power: 0 barlow527 is on a distinguished road
Default CRX motor Swap need Help!
I have a 90 Honda CRX DX. Right now it has the DPI D15 in it. I want to install a ZC motor D16 like that are in the CRX Si's. Do I just need the ECU for the motor or what? Is the wiring harness different? Please help me! Reply to this thread or PM.
From what I have gathered so far. I need a PM6 or PM7 ECU, OBD0 D16 wire harness, 88-91 D16 ZC motor and trans (mine is done). What else? Any help is greatly apperciated!
barlow527 is offline   Reply With Quote
Old 05-14-2008, 10:14 AM   #2
CRX-YEM's Avatar
Ride:  91 CRX
Rep Power: 86 CRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud of
Send a message via ICQ to CRX-YEM Send a message via AIM to CRX-YEM Send a message via Yahoo to CRX-YEM myspace  FaceBook
For a ZC swap you can use a D16 or D15 transmission either will work. The USDM CRX Si transmission has a better final gear ratio if that interests you. You can get away with using a PM6 ecu but you will be happier with an ECU from an 88-89 Integra. Since you have a DX you will need to modify the wiring harness.
Instead of the ZC motor you can also do a D16Z6 swap. Keep in mind the either motor might need to be rebuilt before you use it.
Dennis
Buy my stuff plz...
Mondaswap For Sale - MPFI, 88-91 CRX, 92-95 Civic Parts
Please don't PM/Email/IM me for technical support. Make a Post!!!
91 CRX DX, 03 Civic EX
"There are 10 kinds of people in the world: those who get binary and those who don't."
"Of all my imaginary friends I don't think there was one I didn't end up having to kill"
CRX-YEM is online now   Reply With Quote
Old 05-14-2008, 01:02 PM   #3
I was going to get a JDM motor that has like 35-40k on it. What is the difference in the 88-91 D16 and the 92-95 D16 and D15. The 92-95 D15 makes 130hp, where the D16 thats a 88-91 makes only 120hp. Can I just a 92-95 motor?
Old 05-17-2008, 08:40 AM   #4
What do I need for a wire harness conversion? Do I need just a Si Harness?
Old 05-17-2008, 11:10 AM   #5
jlicrx's Avatar
to do any engine swap in your car (other than another 88-91 DX/STD engine), you will need to use the engine harness from your DX engine and convert the harness from DPFI to MPFI - engine harnesses are not interchangeable between different models and some times not even interchangeable between different years of the same model - the easiest swap is going to be one where you stay OBD0 and the easiest OBD0 engines to swap are the USDM D16A6 Si, the JDM SOHC ZC non-VTEC 120hp and the JDM DOHC ZC 130hp - all of these bolt right in and will bolt right up to your DX transmission or to any other 88-91 CRX/Civic transmission - the SOHC JDM engines that are 130hp are the D15B VTEC and the SOHC ZC VTEC 130hp - these engines are OBD1 and to run them correctly, you need to convert the car to run OBD1 - you need to use the ECU that matches the engine you are swapping in
ZCspeed Racing
« ls dx swap | Paint »
what motor swap to use.... gunz2165 HYBRID -> EG-EK / DC 5 02-12-2008 12:28 AM
Acura Integra B18B1 Motor swap Tranny, ecu,motor 5spd RSS-Bot Auctions 0 11-11-2007 08:13 PM
WTB ITR Motor Swap and suspension Swap Mikevr4n Parts: For Sale/Trade/Wanted 15 03-31-2005 06:27 PM
86 Motor swap DSHIZNITZ HYBRID -> ED-EF / DA 7 11-23-2003 11:56 AM
Motor Swap - From Above Or Under? fardoche HYBRID -> ED-EF / DA 6 06-11-2003 06:04 PM
