crx project #2
Old 10-14-2009, 11:21 PM   #26
Gay username^
b18a1build's Avatar
Ride:  97 Accord & 91 hf
Rep Power: 19 b18a1build is a glorious beacon of lightb18a1build is a glorious beacon of lightb18a1build is a glorious beacon of lightb18a1build is a glorious beacon of lightb18a1build is a glorious beacon of light
Originally Posted by 95b16coupe View Post
haha, i just checked your thread. it's been 6 months, still no engine, no body parts, no paint.
i have faith it will get done, it's just a shitload of work.
Edit: I have the b16, I have ALL the body parts...but you are right about the paint...Not to thread jack by the way lol
97 f22 Accord
exedy stage 2 clutch
Full exhaust from header to muffler
Cold air
17" Motegi Ro_Ja's
Brembo rotors/pads
91 Crx Hf restoration:
Motor: OBD-1 JDM B16a
Trans: Hydro b16 for now
Tokico Blues
H&R Sport Springs
Front Si Brakes
Energy End Links/Bushings
....check out my build thread
http://hondaswap.com/civic-crx-ef/ne...ration-281596/
Add me on Xbox Live!--- C Reese 517
cod4/waw/forza
b18a1build is offline   Reply With Quote
Old 10-15-2009, 09:31 AM   #27
Rep Power: 7 d16z6si is on a distinguished road
im not going to part the car out i have everything im going to put it all back together now. i went and got anothe pm6 ecu yesterday and, the dash harness and si engine harness for $25
d16z6si is offline   Reply With Quote
Old 10-15-2009, 09:34 AM   #28
motor wise im going to run a turbo f22. im not going to run it remote into the passenger floor and not run a bov SLEEPER o i also picked up a full msd set got it for FREE
Old 10-15-2009, 11:05 AM   #29
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
i have clear corner lights,and the oem corner lights for you..take your pick..
i might also have amber...if the price is right
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-15-2009, 11:34 AM   #30
how much do you want for the oem or the amber i need the 88-89 corners
Old 10-15-2009, 11:37 AM   #31
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
mine are 88-89...make an offer..
GOOD FAST CHEAP,
Old 10-15-2009, 11:44 AM   #32
ambers 20
the oem 10
Old 10-16-2009, 12:19 PM   #33
so i got my dash harness and engine harness put in today and i have no power help please
Old 10-16-2009, 04:19 PM   #34
now its a 91
Ride:  91 civic dx hb with si harness and jdm d15b
Rep Power: 6 89hatchd15b is on a distinguished road
Send a message via AIM to 89hatchd15b
not having power sucks, just trace it from your battery and see were the power doesn't flow anymore. use a multimeter on volts dc black on the negative cable and use the the red lead to see if you have power. you can trace it down to see if it is a blown fuse, a bad relay, or even a loose ground.
89hatchd15b is offline   Reply With Quote
Old 10-17-2009, 07:03 PM   #35
so i got power! my dumb ass forgot to contect the ground wire to the enigine. now i have no power to my fuel pump or spark? im lost on this one
Old 10-19-2009, 05:25 PM   #36
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
Simple! you forgot another ground.... did you put the one on the thermostat housing?
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 10-19-2009, 08:38 PM   #37
yea i got thats the one that i had forgot so i finally got it the motor is out of time so im truckin it to the garage so i can put it on the lift and get that fixed and finish the body kit and exaust
Old 11-02-2009, 04:15 AM   #38
Greenhorn
Ride:  Crx Si 89
Rep Power: 0 orlando8889 is on a distinguished road
this crx is fuckeeeed uppp!!!!!!!!1
orlando8889 is offline   Reply With Quote
Old 11-02-2009, 06:55 AM   #39
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Thank you orlando for your insightful information. I can already tell from your first two posts that you are going to be a valued member of this community.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
phyregod is online now   Reply With Quote
Old 11-03-2009, 03:02 AM   #40
crxprojectcar's Avatar
Ride:  88 b16a rex
Rep Power: 1 crxprojectcar is on a distinguished road
my project crx shell was 80 bones and it looks much better than that man .. mine didint have a ugle ass body kit and was missin some glass but it was straight and very little rust
crxprojectcar is offline   Reply With Quote
My New Project Car Cx bistec Civic and del Sol - EG and EK 134 08-08-2007 11:50 PM
Mac's 94 DB8 project thread AKA: Project Aeris.. ITR stuff, body work.. ect mac_24_seven Auto Multi-Media 165 07-30-2007 01:42 PM
The project allbottledup Auto Multi-Media 20 05-07-2005 05:32 PM
my new project pissedoffsol Members' Lounge 20 01-02-2004 12:50 PM
96 project DEISUL HYBRID -> ED-EF / DA 2 12-15-2003 03:01 AM
