This is a discussion on Crx si with B16a swap Having problems in the Civic and CRX - EF forum
i have a crx si with a b16a swap when i push on the gas peddle it dogs down then it revs fine as long as you keep it above 2,000rpms..it is not throwing any codes.. i rechecked the timing just in case & its ...
| | #1 |
| i have a crx si with a b16a swap when i push on the gas peddle it dogs down then it revs fine as long as you keep it above 2,000rpms..it is not throwing any codes.. i rechecked the timing just in case & its dead on...i changed the injectors & fuel rail for the hell of it.....even changed the fuel pressure regulator...i think i have teh vacum lines right... any one have any suggestions.. thanks.. |
| | #2 |
| actully im having the same problem wit my 91 crx i push in the thottle and it chokes till it gets around 2,rpms idk? i got a b18a1 |
| | #3 |
| *plugs and wires* id say double check all that i had a 91 si with this problem and it was the dizzy |
| | #4 |
| ,... module getting baked to shit the distributor,... those long boots ,... on the plug wires might have hole burned arching out,... vacuum leak,... evap,. sys,... intermittent tps signal,....check the ground points under the dizzyness ,.. and other obvious possible wiring shenanagins ,... |
| | #5 |
| lol look how old this string is ,.. SO,... lmao |
Similar Threads | ||||
| B16a swap 92-95 problems, please help... | 92eg9333 | HYBRID -> EG-EK / DC | 3 | 03-30-2009 10:50 PM |
| b16a swap problems | 1994delsolLS | Members' Lounge | 11 | 09-12-2008 06:26 PM |
| b16a swap problems | c0d0r12 | Civic and CRX - EF | 1 | 03-16-2007 07:56 PM |
| DX to B16A swap problems | crxdxb16a | HYBRID -> ED-EF / DA | 8 | 06-30-2005 02:36 PM |
| B16a Swap Problems / Need Help | magnum000 | HYBRID -> EG-EK / DC | 2 | 02-23-2003 10:22 PM |
