can anyone tell me, or show me a picture of, how the steering rack is connected to the steering shaft that comes down through the firewall. there is no access to the top of the rack, and it doesn't simply pull down off of the shaft. the CRX is a 89 Si.
Ride: 88 Honda Civic HB
universal joint. To take the rack off, you just need to unscrew the bolt that holds the u-joint to the steering rack shaft from inside the cabin/under the dash. It's covered by the plastic boot. IIRC, it's a 12mm bolt, and there's two of them on the u-joint; one that clamps it against the column shaft and one to the steering rack/pinion shaft. Just take out the bottom one.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
k, new problem... removing the old inner tie rods? I got the new ones, and they have some sort of washer with them, the old ones don't have any flats to get a wrench on that i can see. any advice?
#5 |
you get the BRAKE
To remove the manual rack an pinion steering gear...
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#6 |
you get the BRAKE
To install:
#7 |
yeah yeah, i got all that sorted out. the problem i'm having how is removing the inner tie rod from the steering rack it's self. physically the rack is out of the car. i just cant seem to find a way to turn the inner tie rod to remove it.
#8 | |
HONDA HUMPER
Ride: A Spaceship!
big hammers....
na normally they have a spot you can put a wrench on i hope its there and i hope you get it fixed good luck! ![]()
Core support on a 96 Nissan Sentra My CB7 Build (Taking forever to get started) |
| wtb: power steering rack | ballerboi23 | Parts: For Sale/Trade/Wanted | 0 | 01-15-2007 01:42 AM |
| Power Steering Rack | accordguy | HYBRID -> BA-BB /CA-CD | 3 | 04-14-2006 01:07 AM |
| power steering problems | Think | Other Vehicle Discussions | 8 | 01-19-2005 07:37 PM |
| Quicker ratio steering rack for EG? | stmotorsports | Wheels / Suspension / Tires / Brakes | 6 | 06-04-2004 11:53 AM |
| Steering Rack | civicracer901 | Wheels / Suspension / Tires / Brakes | 2 | 01-04-2003 08:34 PM |
