CRX swap decision help
Old 06-16-2007, 03:51 PM   #1
CRX Fan
MBCRXMAN35's Avatar
Ride:  1988 Honda CRX Si
Rep Power: 0 MBCRXMAN35 is on a distinguished road
Send a message via AIM to MBCRXMAN35 myspace
Default CRX swap decision help
Hey, I have an '88 crx si with a d16a6 motor, im debating on just rebuilding the engine or swaping it .. i dont have much of a budget for the swap but i can save up to it if need be. what do you think i should, i was thinking just keeping the d and rebuild to make a pretty fast d to be slightly diff from most ppl
Cr!x Man
Just because you have a fast car, doesn't mean you're a good driver.
MBCRXMAN35 is offline   Reply With Quote
Old 06-16-2007, 03:55 PM   #2
Bored
invisibledemon's Avatar
Ride:  91 Civic Si(R)
Rep Power: 60 invisibledemon has a brilliant future
invisibledemon has a brilliant futureinvisibledemon has a brilliant future
Send a message via AIM to invisibledemon
if your on a tight budget then i would stick to the d. ask blanco about them, he preaches the d series gospel so.... yeah.
Sociopaths and Sadists make the best business men.
invisibledemon is offline   Reply With Quote
Old 06-16-2007, 03:58 PM   #3
CRX Fan
MBCRXMAN35's Avatar
thanks
Cr!x Man
Old 06-16-2007, 04:36 PM   #4
CRX Fan
MBCRXMAN35's Avatar
what kind of rebuild mods should i do to my d?
Cr!x Man
Old 06-16-2007, 05:12 PM   #5
Bored
what are you looking to get from it?
Old 06-17-2007, 08:22 PM   #6
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 25 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Yo bro if your on a budget just do a mini-me swap.
Your in the perfect car to do a mini in, the d16a6 block is the strongest d series block. Just strap a d16z6 head or d16y8 head on your block and youll have a pretty descent whip. Junkyard turbo that beotch and youll be in a pocket rocket.
Search for mini-me swap!!!
WHEN YOU SET A GOAL, IT SIMPLY MEANS THAT YOU HAVE THE ATTRIBUTES TO ATTAIN IT!
801CRX is offline   Reply With Quote
Old 06-17-2007, 09:49 PM   #7
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Yeah, I think a mini-me would be great if you can also swing the OBDI conversion. You have a fair amount of options from there as far as building goes.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 03-18-2008, 09:41 PM   #8
CRX Fan
MBCRXMAN35's Avatar
thanks for the help!
Cr!x Man
Old 03-20-2008, 11:02 PM   #9
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 3 monotech909 is on a distinguished road
OBD-1 conversion is an expensive route to go. Just rebuild the bottum end such as hone cylinder walls and re-ring it (new piston rings) and get a conversion gasket set which is bottum end gasket set. New water pump/timing belt and thermostat. If the cylinder head is good then just resurface it and if you want more compression mill it. Will need a new head gasket of course. Good luck with what ever you decide on doing, Peace!
monotech909 is offline   Reply With Quote
Old 03-21-2008, 01:27 AM   #10
Blanco's Avatar
And an RPM or toggle switch is the wrong way to go. Not only will the correct ECU have the fuel and timing maps for VTEC, OBDI also has better tuning options.
Forum Jump
96 'lude obd2 f22 to obd1 h22 swap questions Drummer0488 HYBRID -> BA-BB /CA-CD 9 02-29-2008 03:05 PM
Help on swap decision 91C-R-X Civic and CRX - EF 6 10-11-2006 01:15 AM
need info on b18 swap gin Civic - EP, FA, FG 1 09-13-2006 09:15 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
2nd gen Integra Swap Info pissedoffsol Swap Articles 0 01-12-2004 02:16 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
