CRX Water Leak
Old 04-23-2008, 02:22 PM   #1
Rep Power: 0 ACME CRX is on a distinguished road
Default CRX Water Leak
Most CRX's I have ever seen leak water where the bottom hatch shock is mounted... right over top of the rear speaker holes. Everytime it rains I end up with massive amounts of condensation on the inside of the windows. I have wasted a set of speakers and some other stuff in my 89 CRX Si. I looked at buying another CRX and it leaked really bad. Anyone know where this is coming from or how to stop it? I took silicon sealer and ran it all the way around the botom of the weather stripping but that didn't help. Any ideas? Thanks.
ACME CRX is offline   Reply With Quote
Old 04-26-2008, 04:13 AM   #2
Rep Power: 0 kyle95jetta is on a distinguished road
I have a 89 crx it has a motor swap out of a 92 civic it's a d15b2 it's crb. it has 17690 miles on the body and 90k on the motor it needs a driver side window and a finder it winsheld is craked and it's auto!!!! call and it me know 336-406-9847 name is kyle asking 1400 obo
kyle95jetta is offline   Reply With Quote
Old 04-26-2008, 12:39 PM   #3
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 11 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
you should have drain holes under the hatch they look like little rubber grommets, take a screw driver and plunge out the holes, chances are the holes are clogged with all kinds of shit
t3t4delsol is offline   Reply With Quote
Old 04-28-2008, 09:20 AM   #4
Thanks. I will try that after I finish the other work. The timing belt snapped on it the other day and not I am tring to retime the motor and see if its salvagable. About where are the drain plugs under the hatch?
Old 04-29-2008, 06:04 AM   #5
Plan B
roninallout79's Avatar
Ride:  91 Hatch Si D16Z2
Rep Power: 4 roninallout79 is an unknown quantity at this point
Send a message via Yahoo to roninallout79 myspace
The other thing to do is check the seal around the hatch window my buddy here in Germany is having the same problem and it rains here all the damn time. His hatch and the quarter windows all need to be resealed. Good luck
PLAN B
CURRENT RIDE
91 CIVIC HATCH
PAST RIDES
94 JEEP CHEROKEE
79 JEEP CJ7
80 JEEP CJ7
90 CIVIC HATCH
69 CHEVY C10 LONG BED
82 S10
roninallout79 is offline   Reply With Quote
Old 04-29-2008, 08:22 AM   #6
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 40 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Your engine is an 'interference' engine, meaning if you jump a lot of timing or snap a t-belt, you can kiss some valves goodbye. For the cost of a used sohc engine these days, just buy another one or do a b-swap.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 04-29-2008, 02:41 PM   #7
Yea I might rebuild the head myself just for fun... and because I have never rebuilt one. Then I will probably sell it. I have been wanting to but a b series in it and I guess now is good a time as any. Still looking for someone with a decent price on the swaps in the Virginia area so I don't have to pay out the butt for shipping it here. But I might now be able to get around it.
Old 08-11-2008, 02:42 AM   #8
Rep Power: 0 1badasscrx is on a distinguished road
i am having the same problem with mine and i dont now what to do i dont even know where is the drain plug the crx is my first car im 15 and dont know much about it
1badasscrx is offline   Reply With Quote
Old 08-11-2008, 02:55 AM   #9
Banned
Ride:  89 Civic Hatch
Rep Power: 0 TravisCadello is infamous around these partsTravisCadello is infamous around these partsTravisCadello is infamous around these parts
myspace
My first car was a 87 Crx Si with a D16a1 Dual cam fully built. my parent bought me it when i was 13 and i worked on it till about when i was 15 and finally got it to start. it was a bad coil in the dizzy after replacing everything else on the motor! i was the happiest person alive when i herd it start. but stupid me i reved the hell out of it after its 4 year rest and red lined it when it was cold and before i knew it i had a blown head gasket and tons of smoke.i drove it while over heating and everything for a long ass time and finnally the little bolt that holds the timming belt tensioner stripped out of the block and threw my timming off several time and i kept half assing it and making it still work till finnally their was no other way of fixing it but pulling the motor and getting it retreaded. i pulled it apart and found a stage 2 act clutch a few goodies. i had it jacked up so high so i could drop the motor from the bottom cuz i had no engine hoist lol and it dropped and broke the oil pan. i gave up on that car. and busted all the windows and spray painted all on it and sent it to a junk yard i highly regret doing all of this!
ANYWAYS, my crx dripped from the hatch also and fried my 1600 watt amp i had and made my car always stink i hated it! mine was from the weather seal around the whole hatch though i just never fixed it.
TravisCadello is offline   Reply With Quote
« 91' civic si | b16a »
Forum Jump
don't drink the water in the Bay Area nootrac22 Members' Lounge 19 09-28-2007 02:11 PM
Water leak on the S14 Silverchild79 Other Vehicle Discussions 20 10-26-2006 08:43 PM
Need help with water leak on 1990 crx HF gasnmyveins Civic and CRX - EF 7 08-08-2006 08:55 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
