Greenhorn
hello everyone im new to the whole honda swap things, all that changed when i bought a 91 civic hatch. i have 225,000 miles on it and the engine is pretty toasted compression sucks, head had a crack ect. I dont want to bother putting forth the effort to save the engine so i want to swap in a newer D16 either a obd1 or 2 non vtech engine.
since i dont know the intricate details involved here are what i need to know. looking at a non vtech 92-2000 d16 if i swap the whole long block with its ecu and harness into my civic. will everything bolt on? or do i have to rewire stuff? if so what do i have to rewire? the trans is a 5spd from a crx si will that bolt up? the civic is fun to drive but the d15 DPFI is just slow. i need a little bit more from my daily driver. MY other car is a 1990 ford probe turbo running around 300hp. THAT car is sick, but its not running right now because my megasquirt setup took a dump due to a wiring error. Im also an ASE certified auto tech and have been in the game a while. im confident in my abilities, i just want someone to guide me as to what i have to do. to make this swap painless thanks alot in advance |
Crazy Insane
Ride: 1990 HB (K.I.A.), 2001 Coupe
DX,STD (DPFI) -> Si,HX (MPFI) wiring
Remember to get extra ECU connector pins for the wires you have to add. I can't speak for all D series motors but I'm pretty sure if it's OBD 0 or 1 and it's not Vtac the wiring shouldn't be (much) different. You'll probably find specific info on a swap for the engine you eventually choose by searching the forum. Good luck man, if you're already a certified auto tech then swapping an engine in a honda should be a cake walk for you! |
Greenhorn
hey guys i got something similar but i want to know
i have a d16y7 in a 90 civic sedan and its auto , its still have the daul point fuel injection and i want to change it to do a multi point swap i have a d16 intake manifold , resister box , and i want to use a obdo ecu so am staying obdo i want to use a p29 ecu tell me what are your responses |
| DPFI to MPFI | efalex | Civic and CRX - EF | 1 | 10-20-2008 01:31 PM |
| obd-obd1 88 civic to d16z6 dpfi to mpfi ??? | fabtoys | HYBRID -> ED-EF / DA | 1 | 10-09-2007 01:16 PM |
| DPFI to MPFI | stivic | General Tech and Maintenance | 1 | 10-23-2006 01:19 AM |
| DPFI to MPFI | BoogieDown | Engine Building | 5 | 10-12-2004 12:23 PM |
| re: dpfi-mpfi? | gene | HYBRID -> ED-EF / DA | 4 | 05-19-2004 09:26 AM |
