d15b VTEC swap into 89 CRX HF
Old 10-13-2008, 11:38 PM   #1
Ride:  89 CRX HF
kg728 is on a distinguished road
Default d15b VTEC swap into 89 CRX HF
Hey, I need some help on a swap I am attempting to do... I recently bought a JDM d15b VTEC that I want to put into my 89 CRX HF.
I know I have to change the ecu to a p28 or a p08--I was wondering which one would be better--in order to get the vtec to work. Also, I want to know what other parts I'll have to buy to make the swap work and which ones I can just use from my current setup with the stock motor (d15b6). The motor came with the d16z6 throttle body, and I was wondering if I could use that, or if I'll have to use one from the d16a6. Or if I'll even have to change the whole intake manifold to the d16a6.
Will the distributor from my current motor work, or will I have to get another one? I was also wondering about the alternator and about all the senors...
Anyways, I was just wondering if any of you guys could help me out. Thanks!
kg728 is offline   Reply With Quote
Old 10-14-2008, 12:06 AM   #2
AHHVTEC's Avatar
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
use the po8, convert to obd1, and drop it in there nothing else needed other than running wires for vtec, and off you go
Old 10-14-2008, 12:18 AM   #3
Ride:  89 CRX HF
Thanks for the help! Are you sure I don't have to change the distributor though? Or the throttle body?
Old 10-14-2008, 12:19 AM   #4
AHHVTEC's Avatar
no, just got to convert to obd1 and run wires for the vtec and thats it
Old 10-14-2008, 12:20 AM   #5
Ride:  89 CRX HF
Also, does anyone have an estimate on what power and gas mileage I'm going to get with the new swap? I have h/i/e mods...
Old 10-14-2008, 12:21 AM   #6
Ride:  89 CRX HF
Ok. Thanks! I'll get to work on it soon then, and see how it works...
Old 10-14-2008, 12:21 AM   #7
AHHVTEC's Avatar
well they come with 130hp
Old 10-14-2008, 12:24 AM   #8
Ride:  89 CRX HF
Yeah, I know that much... I was just wondering if anyone had any idea how much the slight mods might give it.
Old 10-14-2008, 08:25 AM   #9
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
philyphreak2127 is just really nicephilyphreak2127 is just really nicephilyphreak2127 is just really nicephilyphreak2127 is just really nice
Not much. Keep in mind most of these horsepower ratings are unfortunely at the crank. So when it comes down to it you will really only be putting to the ground around 100 horses...If you don't mind me asking why would you swap out a z6 for like 10 more horsepower? Why not spend the money on the motor you have now? I too am going to swap a d15b in my car but that is only cause I screwed up another motor. :-( So the P08 is the right ecu?
philyphreak2127 is offline   Reply With Quote
Old 10-14-2008, 10:19 AM   #10
AHHVTEC's Avatar
because his car does not have a z6. it came stock with a non vtec d15 with about 70 hp
Old 10-14-2008, 03:29 PM   #11
The name's Sam
Oh my fault. I totally skimmed that paragraph and obviously missed a lot. lol Well that answers my question completely. So in that case swap it now!!!
Old 10-14-2008, 08:09 PM   #12
Ride:  89 CRX HF
Yeah, my current motor actually only has 65 hp and puts about 50 to the ground.. lol. It also has about 210k miles on it, and the clutch went bad, so I figured this was a good time to do the swap.
Old 10-14-2008, 08:11 PM   #13
Ride:  89 CRX HF
AHHVTEC, how do you recommend running the wires for the vtec to work?
Old 10-14-2008, 08:29 PM   #14
The name's Sam
Probably not a bad time! lol
Old 10-14-2008, 11:05 PM   #15
Ride:  89 CRX HF
Btw, where can I get a p08 ecu? I'm having a really hard time finding one... I can only find the p28 ecu's...
Old 10-14-2008, 11:23 PM   #16
AHHVTEC's Avatar
a p28 will work also i just like sticking to the ecu thats made for the motor, but just run the vtec wires to the proper pin out on the ecu
Old 10-14-2008, 11:32 PM   #17
The name's Sam
I agree with sticking to the original ecu however I am also having a difficult time finding a p08
Old 10-14-2008, 11:37 PM   #18
AHHVTEC's Avatar
me too lol,
Old 10-14-2008, 11:38 PM   #19
AHHVTEC's Avatar
keep in mind if you use the p08 ecu you need a 1 wire o2 sensor if you use the p28 you need a 4 wire o2 sensor
Old 10-14-2008, 11:41 PM   #20
The name's Sam
geez man if I didn't love working on my car I wouldn't be able to remember all this stuff lol. But does that apply the o2 sensors thing if I run a obd2 to obd1 conversion harness? Doesn't that hook to the pin outs going into the ecu itself? I am a wee bit confused. I am kinda new to wiring.
Old 10-14-2008, 11:45 PM   #21
AHHVTEC's Avatar
the o2 sensor has nothing to do with the obd. its just the way those ecu read the p08 needs a 1 wire the p28 needs a 4 wire, and thats goes for obd1 or obd2
Old 10-14-2008, 11:52 PM   #22
The name's Sam
That sucks. I will have to go look and see if I will have to swap my O2 sensors..
Old 10-15-2008, 11:13 AM   #23
Ride:  1994 acura integra LS
tizok is on a distinguished road
myspace
i had a d15b vtec ina 91 civic 4 door... my very first car... i bought it for 600 hundred... and i beat my friend's 2001 honda civic dx coupe... i love that engine
tizok is offline   Reply With Quote
Old 10-15-2008, 01:17 PM   #24
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
i have a d15b in my 90 si hatch....you will need the dizzy for a d15b since its vtec. the d16a6 dizzy will not work. to wire it for vtec is simple....RYWIRE.COM has the obd0 to obd1 jumper harness with the vtec wiring already in place and its color coded so u just simply match the wire colors with the included instructions. i am using a p28 ecu with my swap with no engine problems other than stoopid emissions crap so it should work just fine
HATCHET_HONDA is offline   Reply With Quote
Old 10-15-2008, 09:38 PM   #25
Ride:  89 CRX HF
Thanks for all the help guys. I just noticed though that the driver's side engine mount doesn't fit right though... Does anyone know where I can find a mount for the engine that will fit my car?
Tags
crx, crx hf, d15b, distributor, intake manifold, swap, vtec
D15B (non-VTEC) to D15B (VTEC) Swap SRASC HYBRID -> EG-EK / DC 7 03-03-2010 11:30 AM
D15B Vtec swap/boost/vtec/? 93civicracer HYBRID -> EG-EK / DC 396 03-16-2008 11:33 AM
d15b vtec swap EMFinite HYBRID -> ED-EF / DA 4 04-29-2007 10:39 PM
d15b-vtec swap konflix si HYBRID -> EG-EK / DC 8 05-05-2005 11:57 PM
D15B vtec swap Kracer427 HYBRID -> EG-EK / DC 15 03-16-2004 11:24 PM
