D15B2 mini me swap
Old 01-14-2008, 01:52 PM   #1
crx project
crxhoppa's Avatar
Ride:  1990 honda crx
Rep Power: 0 crxhoppa is on a distinguished road
Send a message via AIM to crxhoppa myspace
Default D15B2 mini me swap
what exactly will i need for the mini me swap and mpfi swap on a D15B2?
crxhoppa is offline   Reply With Quote
Old 01-14-2008, 05:10 PM   #2
Ride:  91 integra with ls/vtec...
Rep Power: 8 ls/vtechatch91 is on a distinguished road
you will need pm6 or pg7 ecu... i would do pg7... an si ditributor... 88-91... a new intake manifold....it can be any sohc manifold thats mpfi.. i would go with y8 but make sure u get the right one... a vtec head.. i would go with a z6 head.... timing belt... my friend had a mini me and it tore.. his was a sohc zc bottom end with a z6 head.. his beat gsr's all day and they werent stock....
ls/vtechatch91 is offline   Reply With Quote
Old 01-14-2008, 05:10 PM   #3
oh ya and wiring to do they mpfi swap
Old 01-21-2008, 08:16 AM   #4
Ride:  1991 4 door
Rep Power: 0 alexfleury is on a distinguished road
Default mini me?
are there other heads that will work? in particular, I'd like to do this swap without usung a Vtec head. I am not looking for max power, just want a daily driver with a little bit more ummph that the stocker.
thanks Alex
alexfleury is offline   Reply With Quote
Old 01-21-2008, 08:30 AM   #5
HNFTuning
D15Beater's Avatar
Ride:  91 B7/Y8 mini Hatch
Rep Power: 10 D15Beater has a spectacular aura aboutD15Beater has a spectacular aura about
d16y7 head will work good on your 1.5 block
D15Beater is offline   Reply With Quote
Old 01-21-2008, 08:51 AM   #6
Ride:  1991 4 door
Default head info
Is that the same head that would have been in the 91 LX? the 1600 engine?
If it is does the above info still apply about the distributor and ECU?
I really appreciate the info since my car is sitting in the driveway now after it quit running while I was driving it. Probably did braek the cam belt or at least it might have jumped time.
If I need a new head this is certainly the time to consider a swap.
Thanks
Alex
Old 01-21-2008, 09:30 AM   #7
The Kicker of Elves.
Blanco's Avatar
Rep Power: 222 Blanco has a reputation beyond reputeBlanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Try to do a little searching and reading. This topic has literally been covered over 100 times.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 01-21-2008, 07:18 PM   #8
Ride:  1991 4 door
Default searching for info
yeah have done a lot of searching but have found more questions than answers and a lot of contradictory info.
So I'd like to see if I can get some info together.
Alex
Old 01-21-2008, 11:18 PM   #9
Blanco's Avatar
What's confusing about a VTEC head, an MPFI conversion, a D16Z6/Y8 timing belt, and a D16Y7/Y8 cam gear? If you want info about doing an OBDI conversion, search the other EF forum for both "OBDI" (no quotation marks) and my user name.
Old 01-24-2008, 12:25 PM   #10
Ride:  1991 4 door
Default would this be viable?
Blanco, if you are still following this thread, I'd like to ask your opinion.
I have this engine:
D15B2
Found in:
1988-1991 Honda Civic DX/DLX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
1990-1995 Honda Concerto (European Market)
Displacement : 1493 cm³
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
Valvetrain : SOHC (4 valves per cylinder)
Cam Gear : 38 tooth
Fuel Control : PGMFI Dual Point
Redline : 7000 rpm
And if my motor needs a head (likely)
I'd like to install one from this motor:
] D16A8
Found in:
1988-1991 Civic/CRX/Concerto (UK/Europe/Australia)
1990-1995 Rover 216/416 GTi(UK/Europe)
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
Compression : 9.5:1
Power : 125 hp (93 kW) @ 6800 rpm & 108 ft·lbf @ 5900 rpm
Valvetrain : DOHC
Fuel Control : OBD-0 MPFI
ECU Code: PM7
I'd like to keep the motor OBD0 and get the Boomslang wiring harness to do the MPFI conversion.
Obviously I would need the head, intake, injectors, and ECU
What else would I need?
But more importantaly, is this a conversion you would advise?
Thanks for your time and advise.
alex
Old 01-24-2008, 05:32 PM   #11
Blanco's Avatar
You can't put a DOHC head on a SOHC block.
If you're that concerned about the OBDI conversion, just put a non-VTEC SOHC ZC head on your block with the Y7/Y8 cam gear. That head is the same head you have, which is also the same head on the D16A6, and the cam is slightly more aggressive than the A6 cam.
I would also recommend RyWire.com over Boomslang.
Old 01-27-2008, 10:03 PM   #12
Ride:  1991 4 door
Default Excellent !!
That is exactly the info that I needed. I haven't taken my car to the shop yet. It may have jumped time or even could possibly just need a distributor.
But if it needs a head, I will certainly look for the ZC head.
Thanks again,
Alex
Old 03-21-2008, 01:28 PM   #13
Rep Power: 0 90 HB D15B2 is on a distinguished road
i have a 90 HB with a D15B2 dpfi and i wanna know what i need for a mpfi swap and a mini me swap
would help with a list of parts and if possiable how 2 do it and were 2 get parts
90 HB D15B2 is offline   Reply With Quote
Old 03-21-2008, 09:53 PM   #14
Got V-tec?
monotech909's Avatar
Ride:  Whip!
Rep Power: 3 monotech909 is on a distinguished road
Thumbs up
Get a V-tec head best options D16y8 or D16z6.
OBd-0 to OBD-1 harness conversion which I make on a daily basis. --->http://hondaswap.com/parts-sale-trad...-dx-si-114851/
OBD-0/obd-1 jumper harness options Hasport/rywire/locash racing all these make nice jumpers and known.
obd-1 distributer/p28 ecu would be best but you can also use po6 and reprogram it to run v-tec.
monotech909 is offline   Reply With Quote
Old 03-21-2008, 10:46 PM   #15
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 71 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
I would personally recommend your own thread and try doing some research. There is a LOT of information to be found on the site, rather than just thread jacking someone else's thread. Good luck.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406
Originally Posted by Blanco View Post
Headers and a turbo, eh? Brilliant advice, Doctor. Simply brilliant.
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Forum Jump
mpfi+mini me swap on d15b2 ? projectrex88 Civic and CRX - EF 1 10-12-2007 01:57 PM
D15B2 swap Distributor connectors? TexasGripper HYBRID -> ED-EF / DA 0 07-25-2007 09:48 PM
mini me swap hondacrxb16vtec General Tech and Maintenance 1 07-10-2007 02:35 PM
Looking for some help with a mini me swap Statis Civic and CRX - EF 7 06-26-2007 03:13 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
