d15b7 honda crx
Old 09-13-2009, 05:43 PM   #1
Rep Power: 0 9894411 is infamous around these parts
Default d15b7 honda crx
i have a d15b7 i swap into my rex i found out tht a h22a1 has a big bored throttle body i think its a 64mm and the b7 has a 54 to 56mm the only problem im having is tht my car idles at 1500 rpms but when i get on it it hauls idling at 1500 rpms burns more gas and is annoying .....what should i do ?? i dont have the d15b7 throttle body anymore
it has new gasket
new hoses
has been cleaned
and the screw under the throttle where the cable hooks up is completely down is there any other way to adjust it ??
9894411 is offline   Reply With Quote
Old 09-13-2009, 06:42 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
check for any loose/cracked vacuum hoses..also check the iacv and fitv..and check to see if you tightened it down
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 09-13-2009, 08:09 PM   #3
what is the iacv and th fitv is not leaking so i think its str8
Old 09-13-2009, 10:58 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
take them both off the manifold nd clean them..
GOOD FAST CHEAP,
Old 09-15-2009, 03:47 PM   #5
okk will do wen it stopp raining
Used OEM Honda D15B7 Oil Pan D Series D15 Civic RSS-Bot Auctions 0 09-01-2009 03:36 PM
Used OEM Honda D15B7 Alternator Civic Del Sol 92-95 RSS-Bot Auctions 0 08-25-2009 12:17 PM
92-95 1.5 L Honda Del Sol S D15B7 Main Rod Bearings RSS-Bot Auctions 0 07-03-2009 01:36 PM
Engine Kit Honda Civic del Sol S D15B7 1.5 92-95 RSS-Bot Auctions 0 11-16-2008 07:36 AM
need some info about a simple d15b7 to d15b7 swap jdovel21 Civic and del Sol - EG and EK 4 03-28-2008 02:39 PM
