| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | Hi, Can i do a swap from D16A6 to D16A9 in my ED7 civic? The D16A9 is also coming from a ED7 Civic. Will i need anything but the engine? The engine is without wiring, but that I can cope with, if the old wiring will fit on the new engine, just by lengthening it? Will i need the D16A9 transmission? Greetings, Troels. |
| | #2 |
| Junior Member | As far as I know the D16A9 is the same as the Japanese ZC engine It's the only D-Series engine which is DOHC. This will fit in place of your A6 as a direct bolt in, you can use your Si Transmission with this engine no problem. You can even use the A6 ECU I think you will need to use a Distributor from and 88-89 Acura Integra though, and the wiring for the distributor plug need to be fixed a bit. Just check around on the net for some more info on DOHC ZC engine swaps, there is lots of info out there. |
| | #6 |
| Senior Member | |
| | #8 |
| Senior Member | |
| 2004 Civic EX Coupe Swap? | xxstarcraftxx | HYBRID -> EP / DC5 | 11 | 04-26-2009 09:57 PM |
| 99 EK swap help pick motor obd-1 or obd-2 help... | Samuels | General Tech and Maintenance | 2 | 04-08-2006 01:43 PM |
| 99 cougar 3.0 swap ,n20 f/s trade | 10ktgold | Vehicles: For Sale/Trade/Wanted | 0 | 11-09-2005 10:42 PM |
| Swap is complete now... | VTECin5th | HYBRID -> EG-EK / DC | 13 | 05-18-2005 04:02 AM |
| Engine Swaps 101 | pissedoffsol | Swap Articles | 0 | 01-11-2004 06:54 PM |
