| | LinkBack | Thread Tools |
| | #1 |
| Greenhorn | Hey guys I just wanted to share my build with you. Hopefully it will be useful for someone. The write-up is on page 2 of my cardomain site. Check it out. http://www.cardomain.com/ride/2671074/2 Thx for watching. Zion |
| | #5 |
| Greenhorn | Cheers guys! Thx for the post. I'm almost done, caught a little snag and broke a bolt in the block. One of the water pump bolts. I was quite sad, it stopped the show. But tomorrow I'll take it out and hopefully finish by the end of this week coming up. The full writeup should be a goodie. Thanks again, hope it helps someone. Z |
| | #6 |
| Senior Member | nice writeup mang, and the paint scheme on the valve cover is pretty slick. sucks that the wp bolt broke off though. you're mostly there though, so i'm sure it will be running in no time. i did wanna throw this out there though so you can update your page. that's not a fitv on the backside of the a6 manifold, it's a ficsv (fast idle control solenoid valve). its adds extra air into the im, but only when its about 12 degrees fahrenheit outside, or colder. it does this by way of an electric purge type valve, with input from the iat sensor. a fitv on the other hand is mounted on the underside of the throttle body, and is controlled entirely by coolant temperature with no electronic input. it greatly affects the cold start idle, everytime the car is started. also, i wanted to tell you i feel your pain on the removal of the head gasket material gunk. i to struggled for awhile chipping away at the stuff when i did an a6/y8 swap. after a friend made a suggestion to me however, i ended up using an angle air grinder with a light grit pad, and it took all that material off in literally just minutes. i couldn't believe i had wasted like an hour and a half chipping away at the stuff with a razor. not like it will help you now, but in the future if you ever need to remove stubborn hg material, this method worked very well.
__________________ 91 Civic Si b18b1, I/H/E, XSPower IM, 94 teg cluster 96 civic ex in progress.. fixing one thing at a time lol |
| | #7 |
| Greenhorn | HAHA I spent 2 hours and a bit on that damn burnt head gasket! I'll try that next time D16SiHatch. Thx for the post, I'll make that correction. So if my Y8 has no ficsv will it affect the motor? Plus the plug on the backside of the TB is a fitv, not IAT? Did I get my sensors confused? =) Thx again. Z |
| | #8 | |
| Senior Member | Quote:
| D16A6 - D16Y8 Mini Me Swap | Projekt Koncept | HYBRID -> ED-EF / DA | 36 | 08-14-2009 08:40 PM |
| 89' CRX D16a6 (Detailed) Rebuild Write Up LOTS OF PICS!! | 89' Project Civic | HYBRID -> ED-EF / DA | 28 | 08-13-2009 03:21 PM |
| d16y8 needed (mini me swap) | zipppablo | Parts: For Sale/Trade/Wanted | 8 | 06-13-2007 08:05 PM |
| D16A6/D16Y8 Mini Me Swap | Civic_Tacoma | HYBRID -> ED-EF / DA | 0 | 11-02-2005 10:04 PM |
| D16a6/d16y8 Mini Me Questions | Jaime 88dxb18 | Engine Building | 2 | 03-08-2003 03:46 AM |
