SOHC VTEC at its best
Ride: 95 Civic EX Coupe
ahhvtec how would u go about doing that? my brother in law wanna run a integra xsi cluster that has a electronic vss hookup and eliminate the cable.
95 Civic EX Coupe: GSR suspension rear LCAs & tie bar no PS or A/C Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R Xenocron chipped ecu Greddy Type RS bov Tial 38mm WG GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines Spearco Intercooler 450cc DSM blue tops walbro 255 HG and ARP studs Aluminum rad/fan combo from GoAutoworks Competition Clutch Stg5 w/4puck disk BF Goodrich Drag Radials Soon to have: 15" Rota Slipstreams tune by Darren in Baton Rouge, LA |
#5 |
how does the electronic vss run into the tranny? i know on the cable there is a little plate that holds the cable in. is there a certain way to put it into the tranny bc when i changed the clutch it worked fine and when i put the cable back in the speedo didn't work after that.
#7 |
Ride: 88 Honda Civic HB
The actual VSS unit is held in with one bolt(has the gear attached to it). Just take out the cable unit and swap in the electric one.
#8 |
what if i use the cable one? i am pretty sure it was seated all the way in, i placed the small plate that locks it in and screwed it down. the cable is in the sensor firmly, but no speedo.
#10 |
Check the cable in the back of the cluster.
#11 |
yeah that's what i'm gonna check when we do the obd0 b16a swap. i think he might run a integra cluster so i'll check it when we do that. thanks. sorry if i thread jacked. >_<
| can I use an electric speed sensor with a 91 crx Si tranny??? | hatukazi | HYBRID -> ED-EF / DA | 8 | 09-04-2008 07:40 PM |
| F.S. d16a6 motor with five speed tranny from 89 crx si $300obo | mikester1222 | Parts: For Sale/Trade/Wanted | 17 | 05-04-2008 06:46 PM |
| 1990 CRX Si D16A6 Head Sensor | 89Si | Civic and CRX - EF | 4 | 02-18-2008 10:35 AM |
| Speed sensor | ANP320 | ECU's, Electronics, and Tuning | 4 | 06-06-2005 04:26 PM |
| Sir speed sensor | wisemansoji | ECU's, Electronics, and Tuning | 5 | 07-01-2003 03:29 AM |
