D16a6 timing
Old 10-06-2008, 09:05 PM   #1
Ride:  CRX89 D16a6
Rep Power: 0 watkinscrx89 is on a distinguished road
Question D16a6 timing
I was trying to time my motor i was told it was 18. So i got around there it runs for about two min and dies. It will start right back up and do the same thing. Can i get some help from you guys "THANKS"
watkinscrx89 is offline   Reply With Quote
Old 10-06-2008, 11:02 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  97 teggy, 98 jeep GC 4x4, 07 CBR 1000rr
Rep Power: 171 phyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
18 what?
If it runs for 2 minutes and dies I'm going to guess something other than timing. Perhaps a clogged up fuel filter? Or a bad pump?
aleaf.CRX: I don't think I've ever had the steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane one day and attack someone
Old 10-06-2008, 11:57 PM   #3
Ride:  CRX89 D16a6
Default D16a6timing
I was told to set it at 18 degrees the pump is new i guess i could have a bad one.I will check the filter.THANKS
Old 10-07-2008, 08:02 AM   #4
Von Europa
awptickes's Avatar
Ride:  1999 Civic EJ9, 2003 Civic EX Coupé
Rep Power: 59 awptickes has a brilliant future
Check all three filters.
Tank, Firewall mounted filter, injector filter screens.
What ECU are you running? Did you have it tuned?
awptickes is offline   Reply With Quote
Old 10-07-2008, 07:03 PM   #5
Ride:  CRX89 D16a6
Default Timing
Ecu is pm6,no it not tuned just stock. The injector screens?Are they on the mani?
Old 10-08-2008, 04:18 AM   #6
Von Europa
awptickes's Avatar
No, they're inside the injectors. Don't mess with them unless you know that they're dirty. Think of it as a last-resort filter that very rarely gets anything in it. If one of them was clogged, I'd be suprised.
Have you tried the fuel pump relay yet?
Old 10-08-2008, 10:48 PM   #7
Ride:  CRX89 D16a6
Default D16a6timing
Where is the fuel pump relay enginebay or under the dash?
Old 10-09-2008, 05:22 AM   #8
Von Europa
awptickes's Avatar
Dash.
Old 10-10-2008, 08:58 PM   #9
Ride:  CRX89 D16a6
Default D16a6timing
cool thank you ill look
Old 10-11-2008, 04:16 AM   #10
Von Europa
awptickes's Avatar
Drain the gas-tank. Drain it completely, then fill it with a gallon or so of fresh gas, slosh it around, then drain and discard all of it properly.
I've seen what you describe happen before, and it was an egg in the gas tank. Might want to check that too.
Old 10-11-2008, 01:17 PM   #11
Ride:  CRX89 D16a6
Default D16a6timing
I dont think it is the gas in the tank it is good. I clean out the tank a month be for i put in the fuelpump. Im going to check all this stuff out this weekend thank you guys
Old 10-11-2008, 02:12 PM   #12
I <3 HS ;)
Ride:  98 Audi A4 Quattro, b20b EG Coupe, 91 Si hatch.
Rep Power: 0 eurocivic91 is on a distinguished road
I've heard of people spending a lot of money with this situation an it so far has been a slight amount of water mixed with the gas, I know a guy who spent thousands trying to figure out the problem by replacing everything an all it was, was water in the tank with the gas. Check that out maybe..
eurocivic91 is offline   Reply With Quote
Forum Jump
Difference between b16b timing belt and b18c timing belt ??? loverboy HYBRID -> EG-EK / DC 4 09-28-2007 10:49 AM
advanced timing v.s factory spec timing 90htchbck General Tech and Maintenance 6 04-19-2007 02:08 AM
advanced timing vs. factory timing 90htchbck HYBRID -> EG-EK / DC 0 04-17-2007 03:39 PM
Timing belt / timing gear problems swapdohc General Tech and Maintenance 1 05-25-2004 11:43 AM
D16A6 CRX ~ which ECU?? pm6, pm7 jpoenitsch ECU's, Electronics, and Tuning 4 01-21-2004 10:47 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
